20 Most Recent Uniden BC248CLT Base Scanner Questions & Answers
2answers
Clear Channels
On SOME of these radios, you can hold down the #2 key and the #9 key at the same time that you turn the radio on, and it resets all data in the scanner. Let me know if that works.
8/15/2015 3:13:51 AM • Uniden BC248CLT... • Answered on Aug 15, 2015
2answers
I am looking for a scanner that will allow me to
buy a scanner that will pick up all aircraft.......
2/24/2015 7:52:48 PM • Uniden BC248CLT... • Answered on Feb 24, 2015
How do i stop costant satic
question first.... are you using an external antenna ie outside or set top inside?..............are you using an external power supply ie power box or battery?.............has yor receiver got a signal meter in it, if so whats the static signal strenth? jon d
7/19/2014 7:43:39 AM • Uniden BC248CLT... • Answered on Jul 19, 2014
7answers
Change analog scanner to digital
With my scanner, I could not change to digital. As far as I know you cant
7/19/2014 7:13:58 AM • Uniden BC248CLT... • Answered on Jul 19, 2014
0answers
Set clock
Be the first to answer 7/14/2014 2:54:37 AM • Uniden BC248CLT... • Posted on Jul 14, 2014Be the first to answer
Cant stop squelch
first take your scanner away from its currant soroundings and try it in someone elses house cause there is so much interference out there eg worn electric motors in fridges or heating pumps or plasma tv and certain 30" and above tvs, that one could even come from nerxt doors tv. next thing to try is put in an earth spike directly from the scanner to the ground ( has to be mud) or move your arial but try it elsewhere first then youl know if its in or close to your house.
6/24/2014 8:30:03 PM • Uniden BC248CLT... • Answered on Jun 24, 2014
2answers
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
6/24/2014 8:10:01 PM • Uniden BC248CLT... • Answered on Jun 24, 2014
How to program auiden ubc360clt scanner
i need help for uniden ubc360clt hard reset ty
3/4/2014 10:07:22 AM • Uniden BC248CLT... • Answered on Mar 04, 2014
2answers
Bearcat BC144XL Scanner ~ no sound
Try it with an external speaker. The external speaker jack receives the audio from the scanner before it goes to the internal speaker. If the jack thinks there is still something plugged into it, the audio to the internal speaker is interrupted. If the jack is stuck, it may still work with an external speaker.
2/21/2014 8:24:53 AM • Uniden BC248CLT... • Answered on Feb 21, 2014
0answers
0answers
Uniden BC248CLT Base Scanner Logo
204 questions posted
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Uniden Radio Communications
Most Popular Question
radio scanner not receiving
  • Radio Communications
