20 Most Recent Midland 4001 40-Channels Base CB Radio Questions & Answers
Why wont my midland cb change channels
make sure the channel 9/19 switch is off / set to normal
11/25/2014 11:43:29 PM • Midland 4001... • Answered on Nov 25, 2014
What is the proper channel to talk to here in manitoba for cb's
any where between channel one and channel forty.Unless you have side band then its the upper and lower of all these channels.
5/18/2014 9:04:12 PM • Midland 4001... • Answered on May 18, 2014
My Midland 77-106 will not move fron channel
Hi my name is John. Try pressing the EMG. button...hope this helps..
9/2/2010 1:11:20 PM • Midland 4001... • Answered on Sep 02, 2010
I can't seem to get any reception, just noise.
It mostly depends on your antenna location and how far away you are from other radios. The receive gain can be turned up in most radios. I do it here all day long. dodgem250.com
4/12/2010 2:58:50 PM • Midland 4001... • Answered on Apr 12, 2010
Will the midland 4001 still work in the uk?
While it will "work" if used to talk with another US CB model, it is not legal. Also, UK CBs use FM modulation while the US versions use AM. Even if they are on the same frequency, they cannot communicate with each other.
For a good discussion of this, look at the following link:
http://en.wikipedia.org/wiki/CB_radio_in_the_United_Kingdom
2/11/2010 12:25:05 PM • Midland 4001... • Answered on Feb 11, 2010
2answers
Tx and rx
can you clarifiy? please
1/30/2010 3:27:58 PM • Midland 4001... • Answered on Jan 30, 2010
Hi, Could you help me with a wiring diagram for
http://www.geocities.com/open_channel/micwiring.html
10/24/2009 1:39:43 PM • Midland 4001... • Answered on Oct 24, 2009
How do change the frequency on an old cb
If it has a PLL 02A chip they are not to hard to
trick is it hss any thing eleas it will be verry hard.
May be this will help
9/17/2009 2:08:26 PM • Midland 4001... • Answered on Sep 17, 2009
THE WIRES IN MY DAD'S OLD MIDLAND 77-106 MIC. HAVE BROKEN LOOSE
first check out the front for a circle with 27/81 this is the 40 channel (FM). if you cant find the circle it is (AM) and not used as much in the uk. if it means alot to you and your dad post it to cb communications shildon DL4 1HE and i will will see want i can do.
7/25/2009 2:29:18 PM • Midland 4001... • Answered on Jul 25, 2009
Help me!!!
SWR OK? Is it throwing a dead-key carrier? No carrier? Midlands many times will show what looks like a processed modulation signal but is not going out your finals on the radio, and out the antenna. Suggest an external in-line meter to see if there really is a transmitted signal. If there is a signal, look for a broken/bad wire at the mics plug-in end. If no signal on the add-on meter, suspect an audio chip or final that's defective. All three are fixable at a GOOD CB Shop.
1/13/2009 1:28:13 AM • Midland 4001... • Answered on Jan 13, 2009
Lazy signal needle
Probably NOT the potentiometer that assists the meter. I would suspect a abad needle in the meter. I'd see if you can get to the adjuster screw on the meters front. Many times it's hard or impossible to adjust due to the way it's mounted.
1/13/2009 1:21:50 AM • Midland 4001... • Answered on Jan 13, 2009
Midland 78-999 40 Channel SSB/AM CB Radio Base Station. I am looking a user manual pdf
Question edited for clarity. https://www.transmission1.net/viewtopic.php?t=58817 Or Paper copies
VHTF MIDLAND 78-999 AM/SSB Transceiver Owners ...
eBay https://www.ebay.com > Manuals & Magazines A great manual for the classic 78-999 AM/SSB CB base station which is a Legend ... VHTF MIDLAND 78-999 AM/SSB Transceiver Owners Manual with 5 Schematics! US$29.95 · ‎In stock
Midland 78-999 AM/SSB CB Radio Owners Manual w ...
eCRATER https://theclassicmint.ecrater.com > midland-78-999-a... Complete OPERATORS manual with schematics. This is not a service manual, this is the owners manual the radio came with. As shown, mint condition as NEW. US$31.95
6/4/2023 4:20:21 PM • Midland Radio... • Answered on Jun 04, 2023
Where can I get a 12volt dc power cord. For a midland hand held 75-779 cb radio
any place that sells electronics
9/20/2021 12:54:31 PM • Midland Radio... • Answered on Sep 20, 2021
Midland cb radio 40 ch transceiver
Here you go
OWNER'S MANUAL midlandusa.com - Midland Radio
https://midlandusa.com > uploads > 2016/12 > 75-...
PDF Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 is a 40 channel Citizen Band Mobile operation, that is big on performance. 15 pages
HANDHELD CB RADIO - Midland Radio
https://midlandusa.com > uploads > 2012/06 > 75-...
PDF Sep. 10, 2012 - Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 represents state-of-the-art high-tech engineering. Designed for 40 channel Citizen ... 8 pages
Midland 75-785 Owner's Manual - ManualsLib
https://www.manualslib.com > ... > Radio
View and Download Midland 75-785 owner's manual online. ... DC 13.8V CHARGE 40 CHANNEL CB TRANSCEIVER 75-785 SQUELCH VOLUME DC 13.8V CHARGE page 4.
75822 HANDHELD CB TRANSCEIVER User Manual G-300 ...
https://fccid.io > Midland Radio Corporation > 75822
75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
USER MANUAL Midland 75-822 40-Channel 2-in-1 CB Radio
https://www.search-manual.com > midland-75-822-40-...
User manual, Midland 75-822 40-Channel 2-in-1 CB Radio, Midland, 75-822, 40-Channel, 2-in-1, CB, Radio, with, Weather, Alerts.
8/18/2021 11:21:07 PM • Midland Radio... • Answered on Aug 18, 2021
Midland two way radio 7Q-0351C What size fuse is require on the 12 VDC power lead?
I think you meant 70-0351c? I believe this is a 60 watt transceiver. So if you remember ohms law P=IxE or power equals amps times volts so 5 amps times 12 volts equals 60 watts. Use a 5 amp fuse.
8/29/2019 7:24:32 PM • Midland Radio... • Answered on Aug 29, 2019
2answers
Need a manual for midland 79-265
If its a real old radio Midland may not have it---Google that model number with "manual" to see what is available.
5/30/2019 1:05:06 PM • Midland Radio... • Answered on May 30, 2019
Hi . I want to buy midland gxt 1000vp4 two way radio . But the charger of that is US standard 110 /60 . In my country its 220/50 . So is there is an eazy way to make it work ? .. thanks.
go to radio shack or best buy you need a step up transformer .or you can buy a travel kit and you dont need a lot of watts transformer to do this dont let them rip you off on a high watt one.
3/1/2019 5:42:49 PM • Midland Radio... • Answered on Mar 01, 2019
Midland 4001 40-Channels Base CB Radio Logo
Popular Tags
11 questions posted
Top Midland Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Midland Radio Communications
Most Popular Question
seem get any reception just noise
  • Radio Communications
