SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
its possible that the pump is either going bad or there is somethin gin the pumps/sump assy. on this model the unit generally tends to shut down when the pump overheats, and will only restart when the pump cools off, a warnig obout replaing hte pump if need be is the pump is actually 220v. you MUST UNPLUG MACHINE BEFORE SERVICING. its a foriegn brand remember so theres abuncha wierd wiring and the pump is one of them!
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
