Computers & Internet Logo
Anonymous Posted on Aug 26, 2011
I have a new pc case on the front panel connectors their is one hdd led +- and one hdd led plug were do they go my case is a EVO LABS E-6690 BLACK/RED, 12CM LED FAN, INC DOOR AND SIDE WINDOW my mother board is a asrock m3a ucc
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Aug 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
1248
Points
45
Hi Badboy !
you can type the name on the motherboard on Google e.g : asrock m3a ucc pdf
You will find the pdf manual right away. On the 20 th page you will see how to connect the HDD led .I think the case should only have one led for the HDD if it has 2 leds just ignore it because the motherboard has only one place where you can put that led. Be careful and good luck !
  • Anonymous Aug 26, 2011
    thanks for your reply i know the mother board has only one place for the hdd led but the pc case has a lcd display with cpu temp and time date hard drive info and so forth and thats why their is two hdd led +-
1helpful
2answers
Transferring motherboard from Gateway SX2801-07E to another case. How do I connect the motherboard front panel headers?
  1. Identify the headers: Locate the front panel headers on the new case and on the motherboard. Make sure that you have identified the correct headers and that they are compatible with each other.
  2. Check the pinout: Refer to the manual for the new case to determine the pinout for the front panel headers. Make sure that it matches the pinout listed for the motherboard, as mentioned above.
  3. Connect the wires: Use the pinout information to connect the wires from the new case to the appropriate pins on the motherboard. Make sure that each wire is securely connected and that there are no loose wires that could cause a short circuit.
  4. Connect the HDD LED: The HDD LED can be connected to pins 13 and 14 of the front header (LEDH1).
  5. Connect the power LED: The power LED can be connected to pins 3 and 4 of the front header (LEDH1).
  6. Connect the reset switch: The reset switch can be connected to pins 7 and 8 of the front header (LEDH1).
  7. Connect the power switch: The power switch can be connected to pins 10 and 11 of the front header (LEDH1).
Make sure that you connect the wires correctly and securely, as an incorrect connection can cause damage to the motherboard or the front panel components.
1helpful
I have a new pc case on the front panel connectors their is one hdd led +- and one hdd led plug were do they go my case is a EVO LABS E-6690 BLACK/RED, 12CM LED FAN, INC DOOR AND SIDE WINDOW my mother...
You need to look in the handbook that cam with your motherboard for a section labeled 'Connectors' or possibly 'Connections'. There will be one USB 2.0 type prong on the motherboard that is designated for case connections [Power LED, mini-speaker, etc.]. The manual for the motherboard will indicate what order and where on the motherboard your connectors should go.
Good luck with your build. :]
1helpful
2answers
Changed the pc case and i can't find power led and hdd led, can you please help me with the labelled motherboard?ASUS P5GD2-TMX/S
Power and HDD LED's are on the front of the computer case. The connectors for them are there and they can only plug in to one place usually if not the board is labeled as you say . You can't hurt it so try plugging them in where they fit.
Dell Asus M2N61-AX MB front panel connector Nix ATX Gaming case
I assume you mean the HDD,reset,on switch etc where they plug onto the mobo.
Most mobos are labelled on the board but you will need good eyesight to read. They are labelled HDD, RESET, SPEAKER etc.
If not simply look up mobo manual from vendors site. You will need the DELL serial / part number from the old unit though.
I have just gotten a new PC case, but can't find the pwr conn.
The front panel connector is close to the SATA connectors. If you look real close (as in flashlight and magnifying glass) at the printing on the motherboard, you will see "pwr_led", "pwrsw", "hdd led", and "reset" printed on the board. Just match what it says on the wires to what it says on the board. Polarity only matters with the LED's. If they don't work, just swap the leads.
Here is the manual for that mobo:
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001142
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
Front Panel Connector: JFP1 hookup
You can go to the link below and see the directions for that. Turn to page 2-17
http://www.premioinc.com/pc/manuals/mb/m266/m266.pdf
Upgrading BTX Motherboard
Hi, I think you are looking at the front USB pin aray connector. The on/off switch and LED light pins are usualy along the edge of the board nearest the front of the case. They will be marked with ID: lettering:- pwrs, hdd led, rs-sw, pwr led. If your case has one block plug you will haave to gently seperate the segments and plug them on one at a time. The power and reset switch will work either way but the LED will only work when plugged the right way around, it wont do any harm if they are plugged backwards they just wont work, so experiment. regards mistyman
Grand Canyon Tech
Grand Canyon Tech
