First, anytime you remove the bucket, you should turn the unit OFF, before you remove it.
The unit may not be turning OFF when the bucket is full due to a fault Float Valve near the top of the interior of the bucket. It may be stuck in the DOWN position, if you model is so equipped. Jiggle the arm of the float valve to see if it moves freely and is not stick.
As far as the bucket safety removal switch is concerned, you may can find it at the following link.
http://www.appliancefactoryparts.com/search/index.php
I hope this helped you and thanks for choosing FixYa.
Good morning friend, thanks for your post!
Based off what you're explaining it sounds like your Frigidaire dehumidifier might not be leveled. Any time your dehumidifier is not properly leveled water will not drain out the rear but instead into the bucket. I would recommend checking to assure your appliance is leveled. If your dehumidifier is leveled detach the hose to make sure nothing is blocking the water for exiting into the hose. If those steps are unsuccessful and you continue to get water into the bucket please respond back and I can research more information for you. Best of luck. -Matt
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
