20 Most Recent Comfort-Aire BHD-651 Dehumidifier Questions & Answers
Don't know your model specifically, but the float is usually at the top of your water tank and activates the system to shut down by popping up when the tank is full. With some tanks you can actually reach in and sort of clean off the float. Jelly-like stuff can build up on the float after a number of years. Cleaning it off wouldn't hurt.
Comfort-Aire... | Answered on Jan 22, 2015
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Comfort-Aire... | Answered on Aug 13, 2011
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Comfort-Aire... | Answered on Jun 26, 2011
Two things generally cause this problem. If your unit has a Float Valve inside the bucket, it's stuck in the 'Up' position, which under normal conditions, indicates to the unit, that the bucket is FULL. If you don't have that, then when the bucket was last inserted into the bucket holder, it did not trip the bucket removal safety switch. Remove the bucket and reinstall it, making sure that it fits squarely into the hole from top to bottom. Leave the unit ON when you do this, because if you do it correctly, the unit will automatically start and run. Also, be sure that humidity extraction level is set on 32 - 35 %.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Comfort-Aire... | Answered on Jun 13, 2011
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Comfort-Aire... | Answered on Jun 10, 2011
heatman101
Comfort-Aire... | Answered on May 17, 2011
heatman101
Comfort-Aire... | Answered on Apr 23, 2011
When you powered down the unit, did you just turn if OFF using the controls on the unit Or did you unplug it entirely? If you didn't unplug it, it won't reset itself. Leave it unplugged for at least 30 minutes. As far as the blinking bucket full light is concerned ... It's possible that the bucket is slightly out of kilter and is only making partial contact with the safety switch. Especially if it's sitting on uneven soil or when the bucket get partially full the weight of the bucket is pulling it out of kilter because it's sitting on soil, rather than a hard floor. If nothing else, place it on a 1/2" piece of plywood or OSB and level it.
To be totally candid, I have some concerns about leaving a dehumidifier running, unattended in the crawl space of a house. There's to many things that could go wrong that would have disastrous results.
Comfort-Aire... | Answered on Mar 10, 2011
Had same problem in 2008. Had to replace Evap Thermister board and sensor. Parts $120 Labor $50.00.
I am not an expert. Good Luck!
Comfort-Aire... | Answered on Dec 12, 2010
You have a leak in hte sealed system. get an authorized refrigeration center to repair it for you.
Comfort-Aire... | Answered on Aug 11, 2010
If the water reservior is empty then the float is stuck in the full position.
Comfort-Aire... | Answered on May 27, 2010
Sounds like the compressor and if it is that oyu are better off buying new...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Comfort-Aire... | Answered on May 14, 2010
Start with the outlet they are plugged into - any power there?
The only solution I can suggest is to take it apart and check the wiring for any burned or shorted wires.
Also check the control circuit board - most have a small glass tube fuse on them. It is possible it was blown when the house was hit.
Comfort-Aire... | Answered on Mar 30, 2010
Comfort-Aire BHD-651 Dehumidifier Logo
Popular Tags
34 questions posted
Top Comfort-Aire Dehumidifiers Experts
Bill Long
Evan Benson
Evan Benson
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Comfort-Aire Dehumidifiers
Most Popular Question
bucket full light will not
  • Dehumidifiers
