20 Most Recent Soleus CFM-40 Dehumidifier Questions & Answers
2answers
Hose connected but not draining
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
9/5/2014 11:12:21 PM • Soleus CFM-40... • Answered on Sep 05, 2014
0answers
0answers
2answers
2answers
Fan runs, no water collected
It appears that these units have a history of defectiveness. I bought one in late 2010 and it pooped early 2012. If the model is still made, buy a new one, return the defective one in the new unit's packing materials for a refund. Or keep the second (new) unit as a back-up, because the new (first) one may just fail again a short while later.
5/21/2013 3:48:46 PM • Soleus CFM-40... • Answered on May 21, 2013
2answers
My Soleus dehumidifier has stopped working after one year.
Buy a new unit, put the defective one in the new unit's packing materials and return it for a refund.
5/21/2013 3:44:15 PM • Soleus CFM-40... • Answered on May 21, 2013
2answers
My soleus CFM40 has stopped dehumidifying.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
5/21/2013 3:41:38 PM • Soleus CFM-40... • Answered on May 21, 2013
2answers
Freezing problwm; very small amount
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
6/27/2012 8:16:37 PM • Soleus CFM-40... • Answered on Jun 27, 2012
My soleus dehumidifier keeps tripping my fuses on
If it is a GFI protected powerstrip then you likely have a ground fault issue, otherwise the powerstrip may be overloaded (unit should pull around 5 amps on startup) or faulty.
9/25/2011 5:53:32 PM • Soleus CFM-40... • Answered on Sep 25, 2011
Soleus CFM-40 Dehumidifier Logo
56 questions posted
Top Soleus Dehumidifiers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Soleus Dehumidifiers
Most Popular Question
soleus cfm40 stopped dehumidifying
  • Dehumidifiers
