20 Most Recent Soleus Air 25-pint Dehumidifier Questions & Answers
Soleus dehumidifier won't drain through the hose
A couple of answers say the hose should be no longer than 5 feet. Why does this matter? The water is simply draining downhill and out the hose. It isn't being pumped or anything.
3/27/2019 1:44:01 AM • Soleus Air... • Answered on Mar 27, 2019
Have a Soleus Air model GLDEH70F2. I do no9t have the instruction book. I need to know if this one is on a recall list. Also can I hook it up to a regular garden hose for continuous draining. Is there
yes it is on recall list you can go to the gree dehumidifier web site for information hope that helps
9/28/2014 5:17:33 AM • Soleus Air... • Answered on Sep 28, 2014
3answers
Where do I find a
Hi there
Most decent tool suppliers will sell you a kit of bits that are interchangeable with most battery drill/drivers.
Loads of manufacturers fit these raised center screws either hex or torx driver to reduce the number of people who can repair their equipment.
Regards
Gordon
7/8/2013 11:34:03 PM • Soleus Air... • Answered on Jul 08, 2013
No water in bucket after running 8 hours.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
1/6/2010 12:48:30 AM • Soleus Air... • Answered on Jan 06, 2010
Soleus air dehumidifier doesn't collect any water
It works by chilling a set of fins like a freezer. It probably needs gas. Get inside it and feel the evaporator with it running. Keep away from the fan though.
10/13/2021 9:23:17 PM • Soleus... • Answered on Oct 13, 2021
I have a D70E A Soleus Dehumidifier that has begun making a rattling noise.
If it’s the one like move, vibration comes from the pump that takes reservoir water to be evaporated. Mine never seems to shut off and is noisy because there’s no water. And eventually it throws an e4 error saying that some water store is full. I can hear compressor come on nicely and quietly. I’ve cleaned the float switch area that was filthy. I was unable to easily remove and fully clean the inside of the donuts. Perhaps the funk is interfering with the float switch. Next step is to research these float switches for how they work. There in another float switch that is not connected anywhere, nor is there a place that it could connect to.
5/10/2020 6:51:11 PM • Soleus... • Answered on May 10, 2020
HOW do I remove the cover of my Soleus dehumidifier 45 pint model number HMT-D45E-A?
Manufacturer support telephone number on the last page of the online manual: https://www.manualslib.com/manual/831899/Soleus-Air-Hct-D30-A.html?page=12#manual
2/2/2020 8:50:28 PM • Soleus... • Answered on Feb 02, 2020
2answers
What does E5 mean on Soleus Air dehumidifier?
hi Randal. this is all i could find on the internet. Your dehumidifier has sensors to monitor for various conditions that may prevent the unit from operating in a normal manner problem,the led display is showing e5, possible cause,over current protection..solution.unplug for 10.minutes then turn on the unit and if the e5 is still showing contact customer services or a dealer. you could try this link as well to see if its of any help to you. What does E5 mean on Soleus Air dehumidifier Google Search
12/3/2017 5:22:27 PM • Soleus... • Answered on Dec 03, 2017
Soleus Air 25-pint Dehumidifier Logo
11 questions posted
Top Soleus Dehumidifiers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Soleus Dehumidifiers
Most Popular Question
soleus dehumidifier won 39 t drain hose
  • Dehumidifiers
