The convergence chip of your tv is already faulty, replacing this convergence chip will correct the problem, if you are familiar with electronic parts and you want to do it your self. Try to do this. Be sure to unplug the unit before opening it. then remove the back cover of your tv, you will see this convergence chip attached to a large aluminum plate cold the heat sink but to get this chips you must pull out the board and remember the proper places of each connector. and you will be needing this tools soldering iron, soldering lead, desoldering pump. When removing this chips you should be careful with the board you may tampered it and can cause seriuos damage to the tv. r you can contact a service technician to do it for you, and save you from stress good day and best regards.
Convergence output IC's need replacment ,there is two of them one for Vertical and another one for horizontal deflection.One of them is burnt but my suggestion is to replaced both.They are mounted on big hetasink and easy to replaced
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
