Cars & Trucks Logo
Posted on Aug 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a chevy s-10 motor work in a 85 mitsubishi mighty max
Chris Davis
Level 2:
Scholar:
New Friend:
  • Expert 39 Answers
  • Posted on Aug 24, 2011
Chris Davis
Expert
Level 2:
Scholar:
New Friend:
Answers
39
Questions
0
Helped
12763
Points
104
Not without using the chevy transmission (and transfer case if it's a 4WD Mighty Max), Custom Motor Mounts, Custom Transmission Mount, Wiring Modifications, Driveshaft Modifications (either lengthened or shortened, depending on where the transmission or transfer case is located). Possibly shifter hole modifications (if it's a 5-Speed Manual), or Custom Linkage/Linkage Modifications (If it's an Automatic)
What years are the windshield for a 1990 Mitsubishi mighty max interchangeable?
Mitsubishi Mighty Max Parts & Accessories - JCWhitney
www.jcwhitney.com > Mitsubishi
Below you'll find a wide variety of Mitsubishi Mighty Max parts and accessories. Enter the year of your Mitsubishi Mighty Max to get a more customized product ...
Mitsubishi Mighty Max Cars and Parts ' eBay
www.ebay.com > eBay Motors > Cars & Trucks > Mitsubishi
eBayResearch Mitsubishi Mighty Max popular models, prices, photos and read reviews. ...Tell us what you thinkthis item - opens in a new window or tab. Mitsubishi Mighty Max. Share: Mitsubishi Mighty Max Model Years ... Mitsubishi Mighty Max · 1990 Mitsubishi Mighty Max · 1989 Mitsubishi Mighty Max · 1988 Mitsubishi Mighty ...
Mitsubishi Mighty MAX Parts, Mitsubishi Mighty MAX ...
www.carparts.com > Mitsubishi
Through the years, your vehicle's components will succumb to wear and tear, ... In addition to replacement Mitsubishi Mighty Max parts, you may also want to buy ...
What is the torque for installing the crankshaft for the 2.4 mitymax motor?
Mitsubishi Mighty Max crankshaft bolt Questions & Answers ...
www.fixya.com > ... > crankshaft bolt > Cars & Trucks > Mitsubishi
Mitsubishi Mighty Max cars & trucks crankshaft bolt questions and answers. ...Torque specs for mighty max The head torque specs for 1991 mitsubishi mighty max 2.4 I ... 1989 mitsubishi 2.0 motor crankshaft was turned while timeing belt was off. ...how to install a clutch kit on my 1994 mitsubishi mighty max Disconnect the .
1991 mitsubishi mighty max want start in cold weather but will when its warm outside what could be the problem?
if this is carb motor than it needs a manual choke that mounts on inside of lower dash, the kind you see on lawn mowers,,,push and pull.
I've got a 96 mighty max doing the same exact thing(cranks,idles,won't rev up) I've checked backpressure-no clogged cat,fuel filter clean,no codes.I'm a tech for chevy(10yrs) i do know a little about how...
have you checked the accelerator position sensor or the throttle position motor
have you checked the fuel pressure available ( problem pressure regulator
1helpful
1991 Mitsubishi Mighty Max 2D 4X4 V6 3.0L No Start.
you can get pressure specs from your local parts dept, and check injector signal with a noid light
9helpful
2answers
What's the firing order for a 1990 Mitsubishi Mighty Max (4.banger)?
1990 Mitsubishi Truck Mighty Max 2WD 2.4L FI 4cyl
The Firing Order mitsutrk01:
Firing order 1-3-4-2 --------- front | | of | 1 2 3 4 | Distributor rotates clockwise vehicle | | ---------
1990 Mitsubishi Truck Mighty Max 4WD 3.0L FI 6cyl
The Firing Order mitsutrk04:
Firing order 1-2-3-4-5-6 ------- front | 1 3 5 | of | | distributor rotates counter vehicle | 2 4 6 | clockwise -------
Hope help with this (remember rated this help).
1helpful
Per my Chilton's manual tehe bolts should be (cold engine) 65 to 72 FT. Pnds., the cam shaft bearing bolts should be 8x25 = 15 - 19 Ft pnds and the 8x65 should be 14 - 15 Ft Pnds.
The sequence is as follows for the (10 ) head bolts:
7 - 5 - 2 - 4 - 10
9 - 3 - 1 - 6 - 8
I hope this may help,
Tom
I have a 1987 Mitsubishi mighty max; how tight should the head bolts be? What should the torque be?
85 foot lbs start in center work your way out start at 45 ft lbs then 65 then 85
Mitsubishi mighty max pick up 1992
Something keeps draining the battery in my 1992 Mighty Max pick-up. Does anybody have any suggestions?
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
