The problem lies in the way the bucket is reinstalled or the float valve (if yours is so equipped) is stuck in the UP position.
Remove the bucket for it's holder and check for the float valve. If it is stuck in the up position, jiggle the arm to make it return to the down position. Be fore you reinstall the bucket, look at the back wall of the bucket holder. There you will see a trigger switch. It's the bucket safety removal switch. Check it to make sure it's still intact. At 10 years old it may have broken OFF. If it appears to be be intact, install the bucket "squarely" into the bucket holder from top to bottom. Being sure that it makes firm contact with the bucket safety removal switch. When installed correctly, the bottom of the bucket will not tilt down at all.
Also, check the air intake filter as it may be dirty of clogged.
Hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
The light goes out when I install the bucket and is goes on when out. So, I don't think this answer is correct.
