1995 Ford Ranger Supercab Logo
Posted on Aug 14, 2011
Oil pan repl. 1995 ford ranger 3 liter automatic
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Aug 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
7786
Points
30
Oil Pan, Ranger SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Engine Lifting Sling 014-00036
Removal
  1. Disconnect battery ground cable. For additional information, refer to Section 14-01.
  1. Remove air cleaner outlet tube assembly by unclipping air cleaner clamp, loosening hose clamp at outlet tube, disconnecting intake air temperature (IAT) sensor and mass air flow (MAF) sensor connectors, and crankcase ventilation hose.
  1. Remove oil level indicator fan shroud retaining bolts. Position shroud over fan blade.
  1. Remove radiator support bolts. Raise and secure radiator to front core support.
  1. Remove engine mount nuts from studs.
  1. Unclip 42-pin connector from bracket and position it aside.
  1. Install suitable lifting brackets to left and right exhaust manifolds. Attach Rotunda Engine Lifting Sling 014-00036 (or equivalent) to lifting brackets. With a suitable lifting device raise engine approximately 50.8 mm (2 in). Install wood blocks between engine mounts and support brackets. Remove lifting device.
  1. Raise vehicle on hoist. For additional information, refer to Section 00-02.
  1. Drain the oil.
  1. Remove transmission insulator retaining nuts and install a jack stand to extension housing. Raise transmission about 25.4-101.6mm (1-4 in) to gain access for removal of oil pan.
  1. Remove transmission inspection cover.
  1. Remove starter motor splash shield.
  1. Remove starter motor retaining bolts and secure starter aside.
  1. If equipped, disconnect and remove low oil level sensor.
  1. NOTE: Oil pan fits tightly between transmission spacer plate and oil pump pickup tube. Use care when removing pan to avoid damaging either part.
    Remove oil pan bolts and lower pan.
  1. Remove oil pump retaining bolts. Lower and twist pump to allow the oil pan to lower completely. Remove the pump and pan assembly from vehicle.
  1. Remove and discard oil pan gasket.
  1. Clean the oil pan mating surface.
Installation
  1. NOTE: When using silicone rubber sealer, assembly should occur within 15 minutes after sealer application. After this time, the sealer may start to set up, and its sealing effectiveness could be reduced.
    Apply a 4.0-6.0 mm (1/5 inch) bead of Silicone Rubber D6AZ-19562-AA or -BA (or equivalent meeting Ford specifications ESB-M4G92-A and ESE-M4G195-A) to junction of rear main bearing cap and cylinder block and to junction of front cover assembly and cylinder block. Position oil pan gasket to cylinder block and secure it with Gasket and Trim Adhesive D7AZ-19B508-B (or equivalent meeting Ford specifications ESR-M11P17-A and ESE-M2G52-A).
  1. Install oil pump assembly and bolt. Tighten bolt to 40-55 Nm (30-40 lb-ft).
  1. NOTE: If oil pan is replaced with a new pan you must tighten new pan to spec then loosen and retighten.
    Position oil pan to cylinder block and install oil pan to engine bolts. Tighten bolts to 10-14 Nm (7-10 lb-ft).
  1. Remove jack stand and install transmission insulator retaining nuts. Tighten nuts to 85-118 Nm (63-87 lb-ft).
  1. NOTE: When replacing low oil level sensor, use a new metal gasket with a rubber O-ring.
    Install low oil level sensor. Tighten sensor to 20-34 Nm (15-25 lb-ft).
  1. Install transmission inspection cover and retaining bolts. Tighten bolts to 10-14 Nm (7-10 lb-ft).
  1. Install starter motor and bolts. Tighten bolts to 22-28 Nm (17-20 lb-ft).
  1. Securely install starter motor splash shield.
  1. Lower vehicle.
  1. Install lifting device and support engine. Remove wood blocks and lower engine back into original position. Remove lifting device and Rotunda Engine Lifting Sling 014-00036 (or equivalent). Remove lifting brackets from right and left exhaust manifolds.
  1. Remove support straps, lower radiator into position, and install radiator bolts to core support. Position fan shroud and install the retaining bolts. Tighten bolts to 6-8 Nm (52-71 lb-in).
  1. Install engine mount nuts and tighten to 98-132 Nm (72-97 lb-ft).
  1. Connect 42-pin connector to the bracket and install oil level indicator.
  1. Install engine air cleaner outlet tube assembly. Connect IAT sensor, MAF sensor, and crankcase ventilation hose. Securely tighten the hose clamp.
  1. NOTE: When battery has been disconnected and reconnected, some abnormal drive symptoms can occur while powertrain control module (PCM) (12A650) relearns its adaptive strategy. Vehicle may need to be driven 16 km (10 miles) or more to relearn strategy.
    Connect battery ground cable.
  1. Fill crankcase with correct viscosity and amount of engine oil.
  1. Start engine and check for oil leaks.
    Oil Pan Installation - Ranger
    Hope this helps
How can I change my 3.0 Liter oil pan gasket
Hi, Im AL the owner of Big As Auto Repair.
I actually own a 1995 Dodge Spirit 3.0 and its not to difficult. The hardest part is removing the bracket on the transmission so you can remove the dust cover for the flywheel. (1) Drain the oil. (2) Remove the transmission bracket and the dust cover. (3) Remover all the pan bolts except one, just loosen this one so you can pry the pan off, because the pan will be stuck on. (4) Clean the engine block and the oil pan very clean. (5) Install the gasket OR sealer which ever it calls for and install the pan and fill with new oil and filter. Hope this helps and please visit my Auto-Repair-Website: http://www.bigasautorepair.com/
I cant locate the oil sending unit and I was wanting to know if you could tell me where it is. Its a 1990 Ford Ranger 2.9L V-6 Automatic.
Under hood, driver side, lower enginearea, beneath exhaust manifold, left side of oillevel sender, above oil pan rail, mounted in block .... if it is not there it is on the back of the engine on the passenger side below the intake manifold on the block...
How do I remove oil pan from a ford 2003 3.0 liter?
First lift up the car by using jack stands.Then the oil needs to be drained from the oil pan.There will be nut that has to be removed to drain the oil. Remove the bolts holding the oil pan to the engine block with a ratchet. Use an extension attached to the ratchet to facilitate removal.Also remove the sealant stuck on the engine block area where oil pan was placed.
--------- Refit the replacement oil in the reverse order. ------ this will help.Thanks.Helpmech.
2helpful
What is the firing order on the 95 3l v6 on the Ford Ranger
1995 Ford Ranger 3.0 liter V-6 VIN "U"
Hope helps (remember rated this).
2answers
A howling noise in the rear end.
The final drive (diff) could be low or out of oil. Have a look around inside of the rear wheels for any oil leaks. Also ckeck the pinion seal. But get oil into the filler plug before you do anyting else.
Oil pan leak on 1994 bronco with a 5.0 liter
Oil Pan Removal
  1. Remove the bolts attaching the fan shroud (8146) to the radiator (8005) and position the fan shroud over the fan assembly.
  2. Raise vehicle.
  3. Remove exhaust manifold-to-exhaust pipe.
  4. Disconnect the oil cooler line at the left side of the radiator if equipped with an automatic transmission (7003).
  5. Remove the nuts and lockwashers attaching the engine support insulators to the chassis bracket.
  6. Drain the crankcase.
  7. Loosen transmission mounting nuts.
  8. Raise the engine (6007) and place wood blocks securely under the engine supports.
  9. Remove the oil pan attaching bolts and lower the oil pan (6675) onto the crossmember.
  10. Remove the oil pan from the vehicle.
Oil spec
1995 HONDA ACCORD 2.7L 6-cyl Engine Code C27A4 C27A1
Engine Oil Grade 1......API All TEMPS......5W-30
Manual Transmission,......SJ All TEMPS......10W-30, optional 10W-40
Automatic Transmission,MPZA......AF2
CAPACITIES:
Engine, with filter..........4.4 liters
Automatic Transmission, MPZA Initial Fill..........2.7 liters
Automatic Transmission, Total Fill
4 speed MPZA..........6 liters
Manual Transmission, ..........1.9 liters
1995 HONDA ACCORD 2.2L 4-cyl Engine Code F22B1 VTEC
Automatic Transmission,A0YA......AF2
CAPACITIES:
Engine, with filter..........4.3 liters
Automatic Transmission, A0YA Initial Fill..........2.4 liters
Automatic Transmission, MP0A Initial Fill..........2.4 liters
4 speed A0YA..........6 liters
4 speed MP0A..........6 liters
5helpful
2answers
Location of oil sending unit? on a 1990 ford ranger with a 2.3l
Drivers side about 3" from the back about 2" from the oil pan. Will have a single black wire leading from it to the wire harness
Hope this helps
Please leave feedback Thanks
1984 ranger with 2.8 liter
If you have many miles on it you may have "Blow By" caused by oil and pressure escaping past the rings causing crank case pressure ... sometimes pushing out oil through the breather. With the engine hot and running ... remove the oil filler cap and see if it pops up ... like it's being pushed up from the inside.
5helpful
2answers
Ignition wiring
firingorder6a.gif firingorder6.gif 1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6 1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
