U reset machine in service mode and then update firmware
You need to load the proper firmware. do you have a card that you can load the firmware onto? i can load the software on a card and send it to you if needed....
Hi Ty. I have a card to load this but it's a 4G card. Must I have a 128M card? Can I just obtain the card from you? How do I get in touch? I couldn't get the firmware to install on my 4G card using cygwin.
yes you will have to download the bizhub c351-c450 fw and then load the firmware imaging tool put your CF card in a CF adapter and (DO NOT FORMAT IT) then select the card in the imaging tool and then select the firmware to be loaded (the fw will be ziped so unzip it) then load it if you get success then turn copier off and plug in the card and booom your copier will load it. then when done remove card and your fixed but if you cant do that ill help ya.....
the 4gb card will not work it has to be no bigger than 512 but 256 is reccomended
Sir, can you send me the firmware for bizhub c351
