Tip & How-To about LG KU990 Viewty
Set up a GPRS data connection for email
Set up a GPRS data connection for email boxAdd('subj0', cBoxClosed);
Please note: Please note that you need a POP3 email account in order to send and receive email messages on your phone. You cannot access web-based email accounts (e.g. Hotmail accounts). 1 Find "Access points"
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press Access points.
2 Create new or edit existing data connection
  • To create a new data connection:
  • Press Add.
  • To edit an existing data connection:
  • Press the required data connection.
  • Press the icon to the bottom left.
  • Press Edit.
  • Press the Connection title input field.
  • Press C to clear the input field.
  • Key in EMAIL GPRS and press OK.
3 Select data bearer
  • Press the Bearer drop down list.
  • Press UMTS or GPRS.
  • Press OK.
4 Select authentication
  • Press the Authentication drop down list.
  • Press PAP or CHAP.
  • Press OK.
5 Enter username
  • Press the Username input field.
  • Key in user and press OK.
6 Enter password
  • Press the Password input field.
  • Key in one2one and press OK.
boxAdd('info6', cBoxClosed); The APN name general.t-mobile.uk must be in lower case letters. 7 Enter APN name
  • Press the APN input field.
  • Key in general.t-mobile.uk and press OK.
8 Save and exit
  • Press Save.
  • Press Disconnect to return to stand-by mode.
LG KU990 Viewty Logo
i cant send an email. can you help me?
trt this one
Goto Messages - Email - Settings - New Account
Give a name for the account (Yahoo)
Settings
Connect using - give your gprs connection name
Email address - your email address
Connection type - POP3
Incoming server - pop.mail.yahoo.com
username - your email username
password - your email password
outgoing server - smtp.mail.yahoo.com
Now goto advanced settings
Set the check interval
Encryption - TLS/SSL
Incoming port - 995
Outgoing port - 465
i recently bought a samsung B3210 cell phone, cant read or send emails. its keeps on saying server error. what can i do to fix this
Here is a quick tutorial of configuring Samsung Star S5233 Star 3G S5603 S5600 Preston Star WiFi for setting up the email client inside the phone with its POP3 Settings for G mail NOTE VERY FIRST ENABLE POP3 FROM YOUR G MAIL ACCOUNT SETTINGS LOG IN TO YOUR G MAIL ACCOUNT ON TOP RIGHT CLICK ON SETTINGS THEN CLICK FORWARDING and POP3 THEN ENABLE POP3 FOR ALL MAIL OR YOU CAN SELECT OTHER OPTION. BUT AT LEAST POP3 MUST BE ENABLED. THEN SAVE CHANGES POP3 G mail Settings For Samsung Star Cellphones Go To Menu Messages Click Settings Email Then Touch Email Setup Wizard Notice will Touch OK Give name to your account E g G mail Enter your email id your name at g mail.com Then Enter Password for your account Incoming Server type POP3 Incoming Server pop.g mail.com Outgoing Server SMTP smtp.g mail.com Secured Connection Off Then touch OK it will display your POP3email account configured successfully Now press back button and tap on Email Accounts, then touch the email account you have just created. There some more option than above you just have to edit that recured Connection: Off POP3 Port 995 SMTP Port 587 Now tink he option APOP Log in Download Limit 500 Secured connection SSL choose SSL for second option only not for first option Retrieving Option Choose Subject only Keep On Server Tick My Address Username Password same as you entered above POP before SMTP Dont Tick SMTP Auth Tick Same as POP3 IMAP4 Tick And Finally Save All Settings.That s it Now you can retrieve your message from your mail box and on Download to download all messages But Do you want your Samsung star phone to automatically download your messages Here is a small option they have given for that.Go To Message Settings Email Receiving Options Download Limit 300KB Auto polling Home Network Only Following option is time after when email is downloaded automatically Polling Frequency 30 Minutes you can choose higher if you want Send read report: Tick And again your emails will be automatically recovered from server at every 30 minutes. And you get notified near your message notifier on your home screen if there is any unread emails.You can also optionally block email id s or subject that you don t wish to receive on your Samsung Star
to activate gprs in htc p3350
Thank you for choosing Fixya.com
Please follow the instruction below very carefully and make sure that you have load of your sim enjoy.
For Globe Subscribers:
For a complete listing of compatible MMS & GPRS phone handsets — send NOKIA, ERICSSON or SAMSUNG (your handset model) to 2365.
To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1)
Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
Enter 1234 when asked for PIN to save settings.
Send an MMS message for only Php 5.00 to activate the service.
Note: For prepaid subscribers, please make sure you have credits first before trying to access GPRS/MMS. You won’t be able to use the service if you have zero balance.
For Smart Subscribers:
OTA (over-the air) configuration
a) To activate GPRS *and* MMS
- SET MMS send to 211
- wait for the configuration to be downloaded to your phone (up to 24 hours)
- once downloaded, you will have SmartMMS data account, and SmartMMS WAP profile, and your MMS is configured already to use SmartMMS WAP profile
- you will also receive a confirmation message that your GPRS and MMS have been activated
b) To configure internet access (full access)
- SET INTERNET (handset model) send to 211
- wait for the configuration to be download to your phone, in minutes
- once downloaded, you will have SmartPC data account, and SmartPC WAP Profile
- edit this account to include DNS settings. DNS IP addresses are -202.057.096.003, 202. 057.096.004. you only need one.
c) To configure WAP via GPRS
- SET GPRS T68 send to 211
- once downloaded, you will have SmartGPRS data account, and SmartGPRS WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
d) To configure WAP via CSD (Optional - kasi MAY BAYAD ITO, per minute)
- SET WAP T68 send to 211
- once downloaded, you will have SmartWAP data account, and SmartWAP WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
I suggest you clear all your existing data accounts and wap profile beforeyou do this. If you follow the instructions in this order, SmartPC will have a CID=2. Your dial-up number willbe *99***2#
or to simplify it:
Setting up of MMS and GPRS handsets:
To download SMART MMS phone settings, key in SET MMS and send to 211.
To download SMART GPRS phone settings, key in SET GPRS and send to 211.
Activating SMART MMS and GPRS:
To activate SMART GPRS, key in GPRS ON and send to 333.
To activate SMART MMS, key in MMS ON and send to 333
Upon receiving the configuration settings, select "Save All" to save the settings in the phone.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
For SUN USERS:
Sun MMS
On the home screen, press the Programs soft key, press More to move to the next page.
Press Accessories then select MMS Setup by pressing the Action button.
Provide the following data on the required field, press Ok when done.
q First field: MMS connection
q IP: 202.138.159.78
q Port: 9201
q MMSC Address:
q Message Expiry: 1 day
q MMS Download: Auto
Press Settings, select Data Connection.
Press the Menu soft key then select Edit Connection by pressing the Action button
Select GPRS Connection. Press Menu then select Add by pressing the Action button
Provide the following data on the required field:
q Description: Sun MMS connection
q Connects to: MMS Connection
q Access point: mms
When finished, press Done four times.
Sun GPRS
Press the Menu soft key then select Edit Connection by pressing the Action button.
Select GPRS Connection. Press Menu then select Add by pressing the Action button.
q Description: Sun GPRS
q Connects to: The Internet
q Access point: minternet
Press Done three times. On the Data connection, select Sun GPRS under Internet connection.
When finished, press Done.
Sun WAP GPRS
q Description: Sun WAP GPRS
q Access point: mms
Press Done three times. On the Data connection, select Sun WAP GPRS under WAP connection.
Sun WAP Proxy
Crate a proxy connection
Description: Sun WAP Proxy
Connects from: The internet
Connects to: WAP network
Proxy (name/Port): 193.113.200.195
Type: WAP
To Activate GPRS:
Create a text message, type "ACTIVATE" then send to 2300
please don't forget to rate our answers properly.
2answers
2answers
gprs
you will need to ask your service provider to send you the GPRS/WAP settings for your handset.
they will text it to you, and then u save them and it will be listed in
Menu > Settings > Configuration > Default
select that setting and set it to be the default setting and then click on Act. Def. In all applications (this will activate default settings in all applications that use GPRS)
or if u knew the access point settings and all, u can add a manual setting and make that as default.
cheerz
Apr 28, 2008 • Nokia 7610
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
