20 Most Recent O2 Samsung SGH-E250 Cellular Phone Questions & Answers
here are all codes for E250,
enjoy and dont forget to rate it as it will fix the issue.
*#1111# ------------------ S/w Version
*#1234# ------------------ Dev.Version FW
*#2222# ------------------ H/w Version Rev
*#0206*8376263# ------ S/w Version ,Dev.Version FW,H/w Version Rev,time and Month and year flash *#0206*8378# ---------- Test Mode
*#4777*8665# ---------- GPRS Tool
*#0206*523# ------------ brightness of the display of 1-5
*#7465625# -------------- Interrogate - indication locks
*#0206*377# ------------ Error -- Table errors
*#0206*327# ------------ EEP(01/10)
*#0206*667# ------------ Debug mode
*#92782# ----------------- User agent (samsung-Sgh-G600/G600XEGH3)
*#232337# --------------- bluetooth addrnap uap lap
*#28837# ----------------- S/w Version BT and H/w Version BT
*#288378# --------------- Bluetooth Test
*#56658378# ------------ Look Test (Bomba code in a well-meaning words)
*#638738# --------------- Profiles Gprs- Inet settings (choice of various countries)
*#36245# ----------------- Test Mode (e-mail, mms, etc.)
*#0206*3768665# ------ DRM Tool (java, etc.)
*#777324# --------------- PPP TEST Menu
*#0673# ------------------ Mp3 Test Menu
*#0206*6366# ---------- Memo test
*#4378378# ------------- Gfs test
*#7378378# ------------- RESours Test
*#688# -------------------- Vod Test
*#64898378# ------------ NITZ test mode
*#898378# --------------- Timezone test mode
*#875108# --------------- FM Radio- speaker volume 1-10
*#52828378# ------------ Java Test Menu
*#73887# ----------------- Setup Wizard: (off/on)
*#2769737# -------------- Browser Test Menu
*2767*8451# ------------- Reset
*#738277# ---------------- Auto Profile Setting ( on/off)
*#0206*8376263# ------ S / w Version, Dev.Version FW, H / w Version Rev, time and Month and year flash
*#0206*8378# ----------- Audio Settings [menu (2) H / W test]*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = Check Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class 1 GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got ********)
#*7683# = Sleep variable (
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#9999# = Software version
*#8999*8376263# = HW ver, SW ver and Build Date
*#8888# = HW version
*#8377466# = Same HW/SW version thing
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*6428# = MIC Measurement
#*3230# = Trace enable and DCD disable
#*3231# = Trace disable and DCD enable
#*3232# = Current Mode
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages
*663867# = Dump Mm file
#*536961# = WAPSAR enable / HTTP disable
#*536962# = WAPSAR disable / HTTP enable
#*536963# = Serial eable / Others disable
#*53696# = Java Download Mode
#*5663351# = Wap Model ID [Your Model]
#*5663352# = Wap Model ID [SEC-SGH***X/1.0]
#*566335# = Wap Model ID [SEC-SGH***X/1.0]
*2767*66335# = Check on which model it is
*2767*7100# = SEC-SGHS100/1.0
*2767*8200# = SEC-SGHV200/1.0
*2767*7300# = SEC-SGHS300/1.0
*2767*7650# = Nokia7650/1.0
*2767*2877368# = Reset WAP Model ID to standart
regards
O2 Samsung... | Answered on May 30, 2019
No. If they were on a memory card then you'd have a chance, but not if they were on the phone's internal memory.
O2 Samsung... | Answered on May 14, 2019
visit samsung mobile web site and download
O2 Samsung... | Answered on Feb 21, 2019
Preview error on camera and record video for samsung E250
O2 Samsung... | Answered on Feb 18, 2019
GT-E1080F unlock this please!! here is my EMEI 354657044663341
send here!! aldren119@gmail.com
O2 Samsung... | Answered on Feb 16, 2019
you can use any samsung pc suite which u can get from ur friend if he is using a samsung mobile..
else go to this link and download it for free...
http://www.brothersoft.com/samsung-pc-studio-download-78015.html
pls rate...cheers..
O2 Samsung... | Answered on Nov 09, 2018
go to this site.http://www.samsung.com/us/support/download/supportDownMain.do
select your phone and download usb drivers for your operation system, install and it will detect
O2 Samsung... | Answered on Jul 25, 2018
How can i change IMEI number in samsung e250i?
O2 Samsung... | Answered on Jun 02, 2018
fix this by buying a new phone.
This phone was released in 2006
in 2017 gsm radio band 900/1800/1900 was shutdown by at least 3 major Australian telecommunication mobile network providers.
You will most likely find these frequency bands as there are three on your phone as not being provided by the mobile network provider you picked.
http://www.mobilenetworkguide.com.au/australian_mobile_phone_frequencies.html
O2 Samsung... | Answered on Jan 16, 2018
PUK CODE is not related to mobile software it on your sim so you have to contact your sim providers of call from any other number to your service center and asked them for your sim puk code...
O2 Samsung... | Answered on Dec 03, 2017
Digital Photo Recovery should be tried in your case# Download the free trial verison on your PC, then connect the Samsung phone #memory card# where your lost items located to start scanning# The program is also able to recover video and audio files# For Mac users, please go to Photo Recovery for Mac.
Remember - Do NOT try & write anything back untill you can retrieve your files safely! I hope you good luck. Best regards.
O2 Samsung... | Answered on Nov 23, 2017
Maybe your power button is shorted out. Also it can be a software problem. Contact your local mobile repair man.
O2 Samsung... | Answered on Jul 08, 2017
you have to change your tone or loud tone and must reset the volume of your message tone
O2 Samsung... | Answered on Jun 13, 2017
968 questions posted
Top O2 Cell Phones Experts
asber
RONALD CARTER JR
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
O2 Cell Phones
  • O2 Cell Phones
Most Popular Question
need samsung pc suite samsung e250
  • Cell Phones
