Samsung LE40R88BDX LCD TV, it keeps clicking on start up,
Found blown capacitors we all know the answer the power supply and Dry sold in output area now you must know how to install new one with correct rating.
I had a 42" LG that began taking longer and longer to power up and finally would not come on at all. I opened it up and found several bulging capacitors on the power supply board. I found a company online that sold a replacement kit of the 10 power supply board capacitors for $18. Installed the new caps and the set has been working fine for two years. You do need to be careful since there are dangerous voltage levels inside of the case and you do need to know how to solder. If you have any doubts, find someone who knows what they are doing.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
The main problem is the power supply. In detail, the output capacitor of the power supply causes the problem. I guess, Toshiba or Lite ON didn't consider the aging effect of the output capacitor. You should replace the output capacitor to fix the problem. (In some sites, they recommend to replace the power supply, but don't do that. The new power supply costs over $200 and the capacitor will be less than 50cents.) If you disassemble TDP-S8, in the power supply, you can find the electrolytic capacitor 3300uF/10V. You should replace this with any electrolytic capacitor with the range of 2000uF~4000uF/10~16V. You can download the service manual from some websites (I've paid $5 for this) then you can disassemble the projector. Of course, you need to do soldering to replace the capacitor. I've fixed this problem yesterday and it took about 4 hours for me. Good Luck~~!!
