20 Most Recent Toshiba TDP-S8 Multimedia Projector Questions & Answers
now my problem is solved.
Toshiba TDP-S8... | Answered on Oct 04, 2018
Sounds like you have the wrong bulb or your
unit is overheating, a dangerous issue.
Check for dirt clogged vent openings.
I suggest buy a new one for safety reasons.
Toshiba TDP-S8... | Answered on Oct 13, 2017
Unplug your projector from the power source. Hold down the On/Standby button and the Menu buttons at the same time and plug the power back in as you are holding them down. This will reset the lamp hours used and should remove that message.
Toshiba TDP-S8... | Answered on Apr 30, 2016
Would need more info. How are you trying to connect? HDMI, VGA, Wireless?
Toshiba TDP-S8... | Answered on Jun 11, 2014
Hi, Cutting out after 5 minutes sounds like an overheat fault. On every projector will be a filter that is user serviceable - it will most likely be blocked up with lint. To Clean - locate the filter & remove carefully. gently brush the lint & dust off the surface of itusing a soft brush or vacuum cleaner on its lowest seting. Try not to puncture the filter element. reinstall.
Toshiba TDP-S8... | Answered on Dec 08, 2012
Toshiba TDP-S8 Multimedia Projector Logo
106 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
tdp p75 toshiba projector keeps cutting
  • Office Equipment & Supplies
