20 Most Recent
2008 Keeway F-act 150 Questions & Answers
Jonway 250cc leaking coolant, is it overflow or
G'day bigknc.Never heard of a jonway before.I think they really wanted to call it a "john Wayne"but they probably thought 2 first names sounds a bit geeky.Anyway....First you will have to find the source of the leak .If that beast is leaking coolant from the overflow on the radiator tank then that tells us of a pressurised system either though overheating or a leaking head gasket.If it's leaking from the weep hole on the engine where the propeller pump is then you've got a leaking seal.Could also be a loose hose clamp.Look for the easy fix options first . but you will need to pin point where the leak is....Hope i could help..Tabbycat 282
I have a 150cc jonway scooter. When I open it up
I found that if I run 87 octane gasoline the engine accelerates up to full speed without the skipping and bogging down at any point it is running. It is worth trying. also try putting some "Sta-bil" fuel stabilizer in the gasoline - it has the ability to keep the carbureator cleaner. Not just during the time you are storing it, but rather all the time.
Keeway fact 50 2008 just turns over but not starting
What exactly is it doing when you try to start it? A slow, lazy start is commonly a low charged or weak battery. Just spinning and not trying to start is often a 'No Spark' issue. Turning, trying to start but stalling out is usually a fuel supply problem.
11/8/2023 7:27:00 AM •
Keeway...
Answered
on Nov 08, 2023
Im looking for a diagram to where the fuel lines go on a 2014 tx125 Keeway motorcycle
I don't have specific information on a 2014 Keeway TX125 motorcycle. However, I can provide you with some general information about fuel lines in motorcycles.
The fuel lines in a motorcycle connect the fuel tank to the carburetor or fuel injector. They carry fuel from the tank to the engine, allowing the combustion process to take place. The fuel lines are typically made of rubber or plastic, and they can become brittle and cracked over time, leading to leaks.
In most motorcycles, there are two fuel lines: one for fuel delivery and another for fuel return. The fuel delivery line carries fuel from the tank to the carburetor or fuel injector, while the fuel return line carries excess fuel back to the tank. The fuel return line helps to regulate fuel pressure and prevent vapor lock.
It's important to make sure that the fuel lines in your motorcycle are properly connected and in good condition. A fuel leak can be dangerous and cause damage to your motorcycle. If you're not sure how to properly connect the fuel lines on your Keeway TX125, I would recommend consulting the motorcycle's owner's manual or taking it to a certified mechanic for assistance.
2/20/2023 7:16:45 AM •
Keeway...
Answered
on Feb 20, 2023
Keeway 200 Superlight no brake light
Hi, be carefull red lights are always a sighn of trouble !!!
in your case please check the wiring connection at the oil pressure gauge (usualy in the front of crankcase ) As for the tail bake light, also check wiring connections at the brake pedal switch and front brake switch ( under brake lever) Also check bulb. It will bea good idea to spresd som wd40 all over the electrical connections . Hope this helps
11/3/2017 12:29:56 PM •
Keeway...
Answered
on Nov 03, 2017
