20 Most Recent Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Questions & Answers
How to fix my compact air compressor 12volt 250psi made by Pittsburgh won't come on at all
check fuse -switch--motor--wiring
4/29/2023 1:24:26 AM • Ingersoll Rand... • Answered on Apr 29, 2023
I have an ingersoll rand ssr-ep60 with intellisys
There have a hidden button to turn on to do setting
3/24/2023 4:38:16 AM • Ingersoll Rand... • Answered on Mar 24, 2023
5answers
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
5/8/2017 4:14:43 PM • Ingersoll Rand... • Answered on May 08, 2017
How to change intellisys from bar to psi
does the controller go back to factory settings after powerloss? if so you may have a bad battery inside the controller. it can be replaced with some nifty soldiering skills. other than that a controller replacement is 2k, programming requires you hitting a sequence of buttons on the controller i think its set set f2 f1 then change the bar to psi. it may be different depending on the controller.
9/21/2016 4:37:15 AM • Ingersoll Rand... • Answered on Sep 21, 2016
I installed a used Ingersoll-Rand
I've a ingersoll compressor ssr ep 20 which is shutting down on high airent temperature.
7/7/2015 9:15:53 PM • Ingersoll Rand... • Answered on Jul 07, 2015
What cuases high a/e discharge fault on ingersol rand air compressor
Dirty coolers are always associated with high discharge temps,always make sure your coolers are clean compressor oil filters being clogged can also raise your temp n cause the unit to over heat,and on the much bigger machines if the compressor oil pump fails then you will have severe over heating as the oil flow to the cooler is assisted by the pump!!things like regulating pressure should always be adjusted to the machines specs so it doesn't over pressurize n put load on your airend while the engine is at idle.
7/8/2014 4:55:54 AM • Ingersoll Rand... • Answered on Jul 08, 2014
2answers
I'm working on a Ingersoll rand 100HP stationary compressor with an intellisys 39875158 controller.
Make sure the model of your compressor is design for 160psi if not the main motor trip off and safe valve pop. Goto Main Menu, Operator setpoint+select, Offline/Online+select, arrow up and down to change value.
6/3/2014 2:13:27 PM • Ingersoll Rand... • Answered on Jun 03, 2014
0answers
For the SG intellisys controller, how do you change the online pressure setting?
Goto Main Menu, Operator Setpoint select, Offline/Online. Up/down key to change value.
2/1/2014 10:13:10 AM • Ingersoll Rand... • Answered on Feb 01, 2014
AIR END problem is occurs high pressure inter cooler ararm?
really they have hidden button ?
12/17/2013 6:24:20 PM • Ingersoll Rand... • Answered on Dec 17, 2013
2answers
Ingersoll Rand SSR EP60 60hp
OK, Compressor should be shut down and showing (ready to start) in display. Press load/unload button once then press hidden right button within 3 seconds. This will let you access the set point program. It will include language, temperature and pressure, rated pressure,etc. Make sure you look at the data tag affixed to the unit and see what the rated pressure is for your unit. You can endanger yourself and equipment by over pressurizing the components of the compressor.
12/16/2013 10:16:30 AM • Ingersoll Rand... • Answered on Dec 16, 2013
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
Popular Tags
93 questions posted
Top Ingersoll Rand Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Ingersoll Rand Tools & Hardware - Others
Most Popular Question
air end problem occurs high pressure
  • Tools & Hardware - Others
