20 Most Recent
Ingersoll Rand Ingersoll-Rand 1/2 in. Drive Impact Wrench Questions & Answers
My ir 223 impact trigger doesnt work ,,,I took it
You can purchase a repair kit from Ingersol that will have the spring and pin. You will need to make sure the fitting on the inlet that has the screen installed is still there or the pin and spring will come out again
Does it have any arrow located on the compressor showing its roation
normally compressors rotate in the same direction as the driving motor. If it is direct couple and the motor spins clockwise then the compressor will spin anti-clockwise as it is viewed from the coupling end. If it is belt driven then it will be the same direction as the motor. Look for an arrow cast in the housing face or mount plate or look for an arrow in the pulley spokes or vanes.
High intercooler pressure
1 st you'll have to detrimine if this is a sensor fault or a real pressure problem , disasemble intercooler to ck for blockage
