20 Most Recent
Mantis Electric Mini Tiller/Cultivator Questions & Answers
I used my mantis electric
a mantis tiller is low end. It does not have the weight to do any real tilling. Granted they are all gonna be hard to control, but unless you have, a bed that is soft soil , it will not work.
We have a Mantis electric cultivator that won't
Electric tiller, and it will not run ?
I would check the cord that you plug into.
You must remove the plastic housing, by removing the screws.
Next look at the plug, is it in good shape, has anything been pulled out of it ?
The motor brushes should also be inspected.
Please let us know, we repair all Mantis equipment.
Mantis to stroke
either the choke is still on
or
the air filter is so dirty that it is acting like a choke
either way, replace your spark plug and air filter
if your air filter is foam, you can clean it in gasoline, just be sure to air dry it before refitting it and tring to run the mantis
the carburator can be dirty and or having the screws out of adjustment.
thy the spark plug and airfilter first
Crt or srt tiller?
* CRT or SRT -- These are two terms you will see on rear-tine tillers only.
o Counter Rotating Tines are best for heavier duty jobs and for breaking new ground.
o Standard Rotating Tines are good for aerating the soil and help propel the tiller forward.
Older mantis 7222E Hedge Trimmer has no spark
You have nothing connected to kill tab on the ignition module? The module is asymmetrical so it can't be installed backwards.Measure coil secondary resistance of both original and new module. I don't have the exact spec and range can vary widely in small 2 stroke.Are there any calendar dates on it... not finding the model as Mantis.Comment for further assistance.
Mantis cultivator when starts at first dies at low idle
Implies carburetor low speed fuel circuit lean. Increase low speed fuel/air.
Initial setting is 1 1/2 turns. Increase idle speed enough to keep the engine runnning so a proper adjustment of the low speed air/fuel mix can be completed.
Basic rules; Always adjust low speed a/f first, then open throttle and adjust high speed a/f. Any low speed adjustment must be followed with a high speed adjust. Error on the rich side for high speed. Allow engine to reach operating temperature for final adjustment.
Other potentual issues, fuel quality, fouled carburetor, old impulse diaphragm (carb), carb to engine intake gasket leak, crankcase leak.
Removing tines makes it easier (safer).
Where is the engine number on mantis tiller an old one
In the Mantis 2-cycle tiller:
SV number is located between the gas tank & the carburetor, behind the gas line, on a black and silver tab on the silver engine housing. It will consist of the letters "SV," a number and another letter.
