20 Most Recent
Mantis Electric Tiller Questions & Answers
How do I take apart the electric motor
Lets start with Symptoms. Why are you taking it apart in the first place? What was it doing? How long has it been acting up? DId it stop while you were using it? is the problem intermittent?Electric motors get blamed for failures all the time when it is usually switches, connectors or wires that are failing.
Electric mantis keeps stopping
could be the battery has developed a memory from only partially charging it causing these symptoms .try checking the voltage in battery before and then immediately after it quites to confirm.if no issue found run it untill it stops and check electrical for over heating parts.
Older mantis 7222E Hedge Trimmer has no spark
You have nothing connected to kill tab on the ignition module? The module is asymmetrical so it can't be installed backwards.Measure coil secondary resistance of both original and new module. I don't have the exact spec and range can vary widely in small 2 stroke.Are there any calendar dates on it... not finding the model as Mantis.Comment for further assistance.
Mantis cultivator when starts at first dies at low idle
Implies carburetor low speed fuel circuit lean. Increase low speed fuel/air.
Initial setting is 1 1/2 turns. Increase idle speed enough to keep the engine runnning so a proper adjustment of the low speed air/fuel mix can be completed.
Basic rules; Always adjust low speed a/f first, then open throttle and adjust high speed a/f. Any low speed adjustment must be followed with a high speed adjust. Error on the rich side for high speed. Allow engine to reach operating temperature for final adjustment.
Other potentual issues, fuel quality, fouled carburetor, old impulse diaphragm (carb), carb to engine intake gasket leak, crankcase leak.
Removing tines makes it easier (safer).
Where is the engine number on mantis tiller an old one
In the Mantis 2-cycle tiller:
SV number is located between the gas tank & the carburetor, behind the gas line, on a black and silver tab on the silver engine housing. It will consist of the letters "SV," a number and another letter.
