20 Most Recent Sanyo Xacti VPC-CG9 Flash Memory Camcorder VPC-CG9BK Questions & Answers
0answers
0answers
Problem with memory card
What model Sanyo camera? What type and size memory card? Just what problem are you encountering? Is there an error message?
10/15/2013 10:53:57 PM • Sanyo Xacti... • Answered on Oct 15, 2013
My waterproof sanyo camcorder is not working
Just let it dry in room temperature for a day. Then try switching on. If it still doesn't work take it to a store.
10/30/2012 3:53:03 PM • Sanyo Xacti... • Answered on Oct 30, 2012
Sanyo VM-EX220P 8mm Video Camera. Hello my camera won't play any of my cassettes. It all comes up scrambled?!
Question edited for a lot more clarity. Question moved from Televisions category. When was the last time the head was cleaned? It may also need servicing or Adjustment.
Sanyo VM-EX220P Adjustment Manual
https://www.manualslib.com > ... > VM-EX220P View and Download Sanyo VM-EX220P adjustment manual online. 8 mm. VM-EX220P camcorder pdf manual download. Also for: Vm-ex370p, Vm-ex280p. ..
6/26/2023 6:37:46 PM • Sanyo Video... • Answered on Jun 26, 2023
Hi i have a sanyo hi 8 camcorder 25 plus years old and it loads and ejects and tape flashes continually whats the oroblem
It sounds like your Sanyo camcorder may be experiencing a problem with the loading or ejecting mechanism. This could be caused by a number of issues, including a damaged or broken cassette mechanism, a malfunctioning loading or ejecting motor, or a problem with the camcorder's control board. To troubleshoot the issue, you could try the following:
  1. Make sure the camcorder is clean and free of any debris or obstruction.
  2. Check the cassette for damage, such as broken or bent spindles, and make sure it is properly seated in the camcorder.
  3. Try using a different cassette to see if the problem persists.
  4. If the problem persists, you may need to have the camcorder repaired by a professional.
Keep in mind that due to the age of your camcorder, it may be more cost-effective to purchase a new one rather than repair the old one. However, if the camcorder has sentimental value or is no longer in production, repair may be the best option.
1/2/2023 6:16:38 PM • Sanyo Video... • Answered on Jan 02, 2023
Sanyo VM-D66P error: CASSETTE
There is a pulley that breaks inside but as these have been obsolete for over 20 years, I doubt it is repairable any more. Fully working VM-D66p for £30 on amazon or fleabay.
2/3/2022 1:35:20 PM • Sanyo Video... • Answered on Feb 03, 2022
Hello, I have a sanyo vm d66p camcorder and want to play it through a tv. What cables do I need ? thanks in advance
You need the RF Adapter cables. I have seen items like that at thrift stores. The camera has that barrel connector with 6? pins to connect it to the converter box that output to Channel 3-4. Keep checking ebay or craigslist. https://www.manualslib.com/manual/894346/Sanyo-Vm-D66p.html?page=2#manual https://www.ebay.com/itm/Sanyo-VM-D6P-8mm-Video-Camera-Bundle/163512488835?hash=item26121a9383:g:pLYAAOSwUMBb8MfJ:rk:1:pf:0
2/6/2019 4:14:21 AM • Sanyo Video... • Answered on Feb 06, 2019
0answers
Sanyo vm d6p video 8 camcorder will not record. Any suggestions?
The organic electrolytic capacitors leak and cause issues
4/9/2017 8:32:40 AM • Sanyo Video... • Answered on Apr 09, 2017
I have a Sanyo video plus recorded the tape is stuck in it just get safe in the display when I try to eject
knock power off then hold the eject button in as you switch power back on. This works for discs not sure about videos but its worth a try.
1/20/2017 8:04:11 PM • Sanyo Video... • Answered on Jan 20, 2017
Software updates for a sanyo blue ray dvd player
Contact the Sanyo site, check to see if there is a firmware upgrade for your product. If there is, download it, then follow the update instructions.
12/26/2016 1:39:13 PM • Sanyo Video... • Answered on Dec 26, 2016
I need a service manual
Google it
4/2/2016 7:11:59 PM • Sanyo Video... • Answered on Apr 02, 2016
How do i download from internal memory to computer
hi, Directly connect the camera withe USB cable to the system, system will detect the cam, will get the option for download.
3/6/2016 10:30:22 AM • Sanyo Video... • Answered on Mar 06, 2016
Sanyo Xacti VPC-CG9 Flash Memory Camcorder VPC-CG9BK Logo
6 questions posted
Top Sanyo Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Xacti Sanyo
  • Xacti Sanyo
Most Popular Question
sony hd2000
  • Video Cameras
