20 Most Recent Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D Questions & Answers
2answers
Acer AM1100-E1401B
Try Acers website first and then try driverguide.com
1/16/2020 11:11:53 AM • Acer Aspire... • Answered on Jan 16, 2020
Aspire wont boot no monitor or hd light
Sounds like a failed POST. You could need a new system board.
12/4/2014 11:01:08 PM • Acer Aspire... • Answered on Dec 04, 2014
How to make it fast my acer aspire R7 computer, since 8GB RAM and 1TB HDD intel core i5, but still very slow sometimes cannot play the video
It should play video with 8 meg. The max memory is 12m but you have to take the whole laptop apart to increase it.
8/10/2014 9:06:52 PM • Acer Aspire... • Answered on Aug 10, 2014
Ne demarre pas
"Ne demarre pas"? English please, thanks.
12/23/2013 5:46:06 PM • Acer Aspire... • Answered on Dec 23, 2013
Aces aspire desktop am1100
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Check your RAM. The RAM is located in the middle of the motherboard. There are tabs that you can push to release the RAM. Remove it and put it back in place until the tabs pop out. Loose RAM can cause your computer not to start properly where you want to see a video signal. Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead.
5/5/2013 4:08:50 AM • Acer Aspire... • Answered on May 05, 2013
On my aspire notebook my front headphone jacks gone out can i switch to the second one?how?
This is the DESKTOP category. If you have a laptop, you've only given HALF the model number. should be ASxxxx-6100 (or whatever yours says.)I doubt there IS a second audio-out on the Laptop, as MFR's tend not to put REDUNDANT systems in a laptop if they don't have-to, to conserve space. If there were, a second-one, it would be a Digital Audio-out, and would not have the same connector as headphone jacks.Desktops typically WILL have one in front and one in the back (usually pale-green in color,)...but not lappys.
8/30/2012 6:54:34 AM • Acer Aspire... • Answered on Aug 30, 2012
Headphone jack on the front of my acer aspire m1100 desktop inst working\
only certain types of headsets work with an acer and there should be two slots to plug in to one for headphones one for microphonewhere did the headset come from that is not working? if it's one from an mp3 player or other device like that(single plug) then it won't work in an acer
5/23/2012 2:15:16 PM • Acer Aspire... • Answered on May 23, 2012
Acer mbs8709003
please you att any lcd on load other person and change our system resolution 800 by 600 and att our monitor solve the problem
5/8/2012 5:31:21 AM • Acer Aspire... • Answered on May 08, 2012
0answers
Ello. I wanted to know if
The AHCI can be enabled from using the correct driver but you should have enabled it PRIOR to the OS install
Acer did not always do this but often relied on compatibility mode
The speed increase is often not that much.
The BIOS on that board can be updated but you may find that AHCI still does not work as you expect.
12/19/2011 4:59:59 AM • Acer Aspire... • Answered on Dec 19, 2011
Have an acer am5100-u5201a w/acer f690gvm motherboard
you have to look up the model number off the board and see what chipset you have and so forth and so on. Without the model number off the board there is no real way to tell
9/7/2011 11:22:19 PM • Acer Aspire... • Answered on Sep 07, 2011
2answers
I have an acer m1100
Memory modules are fickle mistresses; sometimes you'll need matching modules of RAM for it to be recognized properly. From what I'm understanding, you're trying to boot a module of 1GB and another of 512MB. Try to swap the native 512MB for another 1GB stick and see if it works. As well, it's a good idea to install RAM modules that were manufactured by the same company.
Before you do that, it's important to understand that the RAM modules are very delicate electronics. It's also entirely possible, if you haven't worn sufficient ElectroStatic Discharge (ESD) safety equipment, that static electricity could render a module useless. Performing a RAM swap in a proper environment and with the proper equipment (ESD bracelets, in this case) minimizes the possibility of static electricity junking computer components.
Also possible, albeit rare, is that the module is simply defective out of the box. If this appears to be the case, then you can simply return it with the receipt for a refund or an exchange.
6/1/2011 1:20:51 PM • Acer Aspire... • Answered on Jun 01, 2011
2answers
My ASUS ASPIRE M1100 Won't turn on after it was
open it up and check if aall wires are in place.try contacting asus if problem persists
3/24/2011 6:23:20 PM • Acer Aspire... • Answered on Mar 24, 2011
I have a Acer aspire
by default the hard drive should have a recovery partition. go to the support section of the manufactures website and you should find detailed instructions of how to boot to the partition. if that option has been corrupted, you can purchase a recovery disc directly from acer. i've ordered nearly a hundred for customers in the past and have never paid more than 20.00 for a disc or disc set.
below you will find a link that will allow you to enter your product serial number and direct you to the purchase of a factory recovery cd/dvd.
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
1/22/2011 4:31:56 PM • Acer Aspire... • Answered on Jan 22, 2011
How to rewire the motherboard
Download this service guide for Acer Aspire Desktop PC -->click HERE!
This manual will guide you to rewire the motherboard .
1/9/2011 3:06:47 PM • Acer Aspire... • Answered on Jan 09, 2011
How do i find out what are all the plugins are for
1) Outside the computer case;
Front:
A) 4 USB ports (Using USB 2.0 technology)
B) 1 Headphone Jack
C) 1 Microphone Jack
D) 1 Memory Card Reader;
"Multi-in-one Card Reader supporting CompactFlash® (Type I and II), IBM Microdrive, xD-Picture Card™ (xD), Secure Digital (SD), SmartMedia™, MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO™ (MS PRO) (selected models)"
Rear:
A) 1 PS/2 Mouse port
B) 1 PS/2 Keyboard port
http://en.wikipedia.org/wiki/File:Ps-2-ports.jpg
C) 1 Parallel port
http://en.wikipedia.org/wiki/Parallel_port
D) 4 USB ports (Using USB 2.0 technology)
E) 1 VGA port. (For an external VGA monitor )
http://en.wikipedia.org/wiki/VGA_connector
F) 1 IEEE 1394a port (Firewire port)
http://en.wikipedia.org/wiki/Firewire_port
G) 6 Audio ports
2) Inside the computer on the motherboard,
A) 1 PCI Express x1 expansion slot
B) 1 PCI Express x16 expansion slot used for a graphics card. (Uses the PCI Express 2.0 technology)
{250 Watt ATX power supply}
C) 2 PCI slots
Acer Support > Acer Aspire M1100 series of desktop computers > User Guide,
http://www.acersupport.com/us/en/product_support.aspx?tab=1
Go to the bold heading > User Manual
Click on the blue >
ASMx100_EXE210_VTMx10_UG_EN.zip
After you click on the above file name a small window will come up.
If there isn't a Green dot in the circle to the left of Save File, click on the circle.
Make sure there is a green dot in it.
Now go below, and click on OK.
Another small window will come up, that has a download progress bar in it.
Write down what is in the top heading of the window.
This is where the Zip file will download to.
It may have Desktop, or My Documents, or Downloads in the info at the top of the window.
Desktop: The file will be on your desktop screen.
My Documents: Click on Start > My Documents
Downloads: Click on Start > My Documents > Then double-click on Downloads
When you see the file name double-click on it
( ASMx100_EXE210_VTMx10_UG_EN.zip )
Another window will open up.
Click on > Unzip
On the top left click on Extract All Files.
Click on Next, Next, and Finish.
Now double-click on the file name next to the red PDF icon.
There's your user manual.
If I have left something out, or the above is not what you had in mind, or you have questions,
post in a Comment.
Would like to hear back from you.
Regards,
joecoolvette
12/10/2010 3:56:01 AM • Acer Aspire... • Answered on Dec 10, 2010
Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D  Logo
Popular Tags
76 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
rewire motherboard
  • Computers & Internet
