20 Most Recent
Dual Electronics XHD-6420 CD Player Questions & Answers
No sound dual xhd6420 92 accord lx
my brother has a 1993 Honda accord and had the same issue, we put it different speakers and it worked fine, don't know what the problem was but it worked
When upgrading an existing single tone car horn to a dual tone how complicated is the extra wiring?
No Simon, that won't work.
What you are suggesting is wiring the two horns in series, and that halves the voltage so you would have two horns running on 6 volts. They need to be wired in parallel. A lot depends on how good the horn's relay is and if it can handle the load of two horns. My thought is that it probably will as many vehicles already have twin horns. The positive lead from the relay needs to split and go to the positive sides of both horn, and the negative of the horns to grounds. Ideally, two relays, two horns, two grounds.
Look at the YouTube video of the guy that added a huge locomotive twin air horn. It is funny as he goes looking for jay walkers! If I remember he had to install a second battery for it as the load for the air compressor, made the engine stall.
Dual xdvd 156bt no power
Check all wiring/connections, fuses, etc. and don't forget the one on the back of the deck itself!
