20 Most Recent
Viking 31 in. DGCU105 Gas Cooktop Questions & Answers
Less than a year ago
Hello, welcome to FixYa.
The short answer is yes it can be repaired, however it requires replacing the glass top unfortunately...and as you may or may not know they are usually well in the range of $500-600 or more.
You can check on the availablilty of your particular cooktop at the link shown here or you may opt to contact a local service center.
http://www.allvikingparts.com/SearchResults.asp?Search=glass+top
Hope that at least answer's your question. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Viking Designer Series gas cooktop not cleaning well
I'm sorry to say that there is not a wonder solution for this. You try laying a damp cloth on the aluminum part to try and allow the moisture to soak in the clean it off.
Don't use anything abrasive as the aluminum will scratch.
The glass of the electric cook top is lifting from the stainless steel frame
www.
vikingrange.com/.../m10103_
viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
My Viking Range top has 4 burners and the
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
We have a viking cook
Some units have a dead man switch, which means that if the filters are not in place correctly the blowers will not operate. Its a safety thing to prevent little ones from dropping toys into a running blower. Double check the filters placement, if the filters are in the proper location than I would look at the power to the blower unit. The vent has two jobs, (1) to raise and lower, (2) to turn on the blower unit once in the full up position. If this is not the case, the upper switch in the vent system has failed. If you already confused, you will need to call a Viking expert to correct this problem. Its not difficult but can be time consuming.
I hope this helps
I have seen this problem twice and found the filters were the problem, rarely replace blower motors.. I’m happy to help further over the phone at
https://www.6ya.com/expert/gere_bf68e6055dd61249
