20 Most Recent Viking 31 in. VGSU101 Gas Cooktop Questions & Answers
3answers
Viking Ultraline Professional Gas stove
Hi
Please check the latching mechanism.Also check the spring attached to the door either of the two is broken and needs a replacement.Please let me know the model no.
7/2/2014 9:55:47 PM • Viking 31 in.... • Answered on Jul 02, 2014
manual
2answers
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
9/2/2012 11:37:08 PM • Viking 31 in.... • Answered on Sep 02, 2012
I have an ultra line
HI,
SAFETY FIRST, Have the unit checked for issues, it not worth the home over a leak. Unless you know about this unit, have your gas company inspect for leaks and supply issues. If you leak is a connection issue, they will advise how to repair, if internal, it should be check right away or prior to using again.
I had seen a simple loose connection cause a lot of damage.
Please be safety, I would be glad to assist you further if needed. I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
8/21/2011 1:54:56 PM • Viking 31 in.... • Answered on Aug 21, 2011
We just bought a house
Hi esgt,
The Ignitor switches have either gotten stuck, maybe being dirty or wet, or the ignitor switches are faulty and need replacing.
The switches are under the burners where you have the gas pipes and valves you will only see one electrical part, that is the ignitor switch. This plastic box has one input (for power) the rest attached to other burners. Check if the wire going to the problematic burner is loose, off, dirty, wet or cut. Repair or replace accordingly.
I'd suggest looking at the wire from the one burner that is working correctly, that leads to the problematic burners - The problem would likely be there.
Hope this helps :-)
* If you found this solution helpful, please accept it
7/16/2011 12:39:26 PM • Viking 31 in.... • Answered on Jul 16, 2011
The clicking won't stop after it has been ignited
Sorry to read about your problem, I hope this helps you out.
You have a stuck switch, try turning back and forth to stop, you may have to turn power off to oven to stop clicking
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/21/2010 9:45:54 PM • Viking 31 in.... • Answered on Dec 21, 2010
When I turn on the burners they make a clicking
you may have a defective gas control or a clog in the gas feeds
12/21/2010 4:37:52 PM • Viking 31 in.... • Answered on Dec 21, 2010
One burner will not light other burner clicks
Under the burners where you have the gas pipes and valves
you have only one electrical part the ignite spark module. This plastic box has
one input the power wire and for outputs one for each burner. Now you can check
if the wire going to the problematic burner is loose or cut out and fix it. If
all wires look ok then the Spark device is bad and need a new one.
12/19/2010 10:49:20 AM • Viking 31 in.... • Answered on Dec 19, 2010
0answers
I have a viking stove.
Use a Magic Eraser sponge and get this cleaner called Star Clean(you buy it on the web from TJT products) it will have them looking like new.
10/26/2010 1:38:31 PM • Viking 31 in.... • Answered on Oct 26, 2010
I have a Viking cooktop with a fan that rises when...
I just finished researching the same issue for my 36" downdraft. It appears that the ost common problem is the little up/down switch.
Most folks on-line were being told that they had to buy the whole top unit for $500.00 plus labor. But an electrical engineerpointed out that allvikingparts.com sold a switch for about $60.00 delivered.
It seems that if one holds the switch for an extended period of time it can heat up and burn a connector - might be a coincidence, but my unit stopped working just after my 4 year old grandson visited for two weeks - I made the mistake of showing him how pushing the button would make the vent go up and down. So the switch probably got mre use in a week than it had in the eight years since it was installed.
You can simply peel your switch off with your finger nail ( it will stick right back). On mine I noticed that the center "wire" hade a dark line through it which probably indicates that it is "burned"
My part is on the way.
Hope this helps - $57.00 is much easier to swallow than $595.00
8/31/2010 1:56:38 PM • Viking 31 in.... • Answered on Aug 31, 2010
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
8/18/2010 11:16:16 PM • Viking 31 in.... • Answered on Aug 18, 2010
Grease-encrusted cast iron trivets
Try soaking in hot soapy water that you've dropped several denture cleaning tablets in. That's helped me get some tough stuff off, or at least loosened up enough that some elbow grease and a scrubbie can finish off the job.
Put them in the oven and run the self clean cycle
Oven cleaner. That stuff is second only to industrial grade hydrogen peroxide
Batender's Friend. That stuff is amazing!
Good Luck
8/1/2010 6:45:00 AM • Viking 31 in.... • Answered on Aug 01, 2010
2answers
It is visible the hinges /w40 has extension nozzle spray the hinges a few minutes open slowly/ by moving little by little until the lubricant or oil penetrate the moving parts of hinges ,
12/22/2009 2:40:09 PM • Viking 31 in.... • Answered on Dec 22, 2009
My VIKING 31
I have the exact same problem, same model. Read the instructions on this website for replacing the ignitors...looks complicated, also generic to all Viking cooktops. Let's see what we response we get.
10/26/2009 1:45:43 PM • Viking 31 in.... • Answered on Oct 26, 2009
I had a spillover last Thursday on my Viking
the smell should disappear when used a few times.
9/30/2009 4:37:04 PM • Viking 31 in.... • Answered on Sep 30, 2009
Could you tell me the average annual energy
sorry but your would need to check gas meter dial when hob is fully on also length of time it is used for.
9/30/2009 4:35:24 PM • Viking 31 in.... • Answered on Sep 30, 2009
Viking 31 in. VGSU101 Gas Cooktop Logo
43 questions posted
Top Viking Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Viking Cooktops
  • Viking Cooktops
Most Popular Question
viking professional 30 inch sparking
  • Cooktops
