20 Most Recent
Tissot T Touch Navigator 3000 T96.1.488.42 watch Questions & Answers
Stuck on 02.10 hrs
You have to change battery. 3 years was a quite long service time for one battery. After replacement your watch will work as brand new.
Rate me, plz.
My Tissot watch display got prob
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please.
Analog hands show 2hour 15minute ahead of the
I have read the instructions and theyare as clear as mud!
If you haven't already tried it, try foll0wing the "local time" setting instructions, with reference to the s#last section "If necessary perform setting..............." This should either alter the hands or the digital display, so that you can get them to agree.
If you still cannot set your watch, then you might find it useful to go to Tissot.com and click on "contact us" and send them an email explaining your problem.
The digital time and the analog time are not synchronized
Here is complete manual for your watch:
http://www.t-touch.com/t-touch_images/usersmanual/140-en.pdf
If you are not successful with this, maybe it's time to change the battery?
Read manual carefully and you will find out how to recognize: I'ts time to change the battery.
Rate me, please.
Wot size battery do I need for a t472 tissot trace
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
Why Touch does not work after battery replacement?
Was the battery empty in the first place, or was the watch already defect?
Did you put in the correct and a new battery? or perhaps you did put n the old battery?
can you measure the voltage of the batteries, to check?
Just a few questions that came up with me.
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase
there is a sunken button between the chronograph start/stop and the winding crown.
Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
