20 Most Recent Tissot T-Touch T33759851 Questions & Answers
In this watch the battery should be changed after one year, depending on how often the features are used. After changing the battery the all reset should be done. Best to take it to an authorized service, and not any non authorized place to change the battery. Get in touch with Tissot for the info about where to bring the watch.
Tissot T-Touch... | Answered on Feb 11, 2018
Are you wearing it? Only reads proper ambient temp when off your wrist. Otherwise it is reading body temp.
Tissot T-Touch... | Answered on Jul 17, 2016
I have the same problem with my t touch one, the first model with round push button, after take it to a battery replacement and service, and ask a tissot representative store, I receive two answers and both says that I have to change the movement... means ... the machine, and if is under warranty will be free, is maybe 6 or more years old so no more warranty, sad but true, I let it be. I will not spend at least 400 USD. to do it, so, try to enjoy the rest of functions left and a nice looking watch.
Tissot T-Touch... | Answered on Nov 12, 2015
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Tissot T-Touch... | Answered on Jan 25, 2015
there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
Tissot T-Touch... | Answered on Nov 01, 2014
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock Incrementation of the minute hand(3 steps=1 minute) Incrementattion of the hour hand(3 steps=1 minute) Press the middle button to validate the setting.
Tissot T-Touch... | Answered on Oct 31, 2014
If you syncro you must touch the center until the option look open the press the middle button for 5 sec and you see the function Synchro.You must set the 2 hands at 12 exactly.greekdimis.blog spot.
Tissot T-Touch... | Answered on Aug 28, 2014
Tip
Replace Battery on a Tissot Touch
When you need frequent re.Syncronizing of your Touch or after 2-3 year
maybe you need to replace the battery.
you need:
a CR1632 3V Battery (about 2€)
a very tiny screw driver
a very sharp knife
With the knife remove the bottom of yout Tissot, (you do not need to unscrew) it's just a cover to pull up like in this imagedcef0c0d.jpg
Now you can clean with a soft brush & remove the dust.
Use the screw drive to replace the battery,
put back the cover & enjoy
on Jun 23, 2014 | Tissot T-Touch T33759851
Renata CR1632
http://www.renata.com/pdf/3vlithium/CR1632_v06.pdf
To replace battery you need to have very small screwdriver and some knife to open back cover.
Tissot T-Touch... | Answered on May 20, 2014
Tissot T-Touch T33759851 Logo
167 questions posted
Top Tissot Watches Experts
Arturs Kalnins
Arturs Kalnins
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
T Tissot
  • T Tissot
Most Popular Question
tissot t touch analog time out sync
  • Watches
