20 Most Recent
True TSSU-48-12-ADA Sandwich/Salad Unit, 12 Cu. Ft., 4 dp Clear poly pans, 2 doors, 4 Shelves TSSU4812ADA, TSSU48-12-ADA, TSSU-4812-ADA, TSSU-48-12ADA, TSSU-48-12-AD, TSSU-48-12-A, TSSU-48-12, TSSU-48 Questions & Answers
I got a true tssu-27 that won't cool what would be the problem with this unit?
Many times the air circulation across the condenser is the problem. Take a look at the condenser and make sure that the condenser fan is running and there isn't dirt or grease blocking air movement. There is also the obvious like a compressor that's not running or an iced up cooling coil. Is the compressor hot? Maybe an additional description would help. Are the fans inside the cabinet running? Good luck hope this helps.
11/4/2014 5:44:47 AM •
True...
Answered
on Nov 04, 2014
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the windingresistance. or you can just cross your fingers and hope the relayand start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
4/18/2013 1:54:30 AM •
True...
Answered
on Apr 18, 2013
No door heat
The Mulluen heaters will be Built into the frame not in the door.
On freezer True T-23, the compressor works around 5 minutes and turn off for around 5-6 minutes and start again for another 5 minutes. I need help
That is what it is supposed to do. It is called cycling and switches off when the set temperature is reached. It is a commercial freezer, so if the door opened and closed often, that is normal?Commercial freezers and fridges have an item called a 'Clixon' that cuts power in the case of the compressor overheating. When was the last time the fins on the compressor coils were cleaned? Could also be a bad door seal letting cold air escape. When you close a freezer door on a unit like that, it should be really hard to open straight afterward due to the suction. Could be a faulty thermostat. Turn the temperature to the warmest setting and see if it still does it? If it does, you need a new thermostat.I just retired after 52 years in catering.https://www.katom.com/598-T23F.html?gclid=CjwKCAiArbv_BRA8EiwAYGs23PKtEzF60_OMVNpHXBlGjHQNdpp0pDZsu0G0lFLqVy2p4qIybG9n8xoCwEMQAvD_BwE..
Why is jenn air jcd2389ge hot around front freezer door frame?
The heat at the opening of refrigerator is usually a sign the condenser coils are dirty. Check the condenser coils for a restriction underneath the unit. Dirty condenser coils will cause poor air flow over the coils and compressor. Poor air flow will cause a lot of problems, including overheating the compressor, the refrigerant and the copper lines. This will destroy your sealed system. The coils need cleaning at least once a year, more often if you have pets.
I couldn’t determine if your unit has an “energy saver” setting. If so, turn it on. Not all refrigerators have energy saver. This is on units with emilion heaters in the wall around the door gaskets. The heaters are to eliminate condensation around the door. Turning ON energy saver turns OFF those heaters. You should notice a change quickly if it’s the heater causing the heat, that is, if you have that model.
Cleaning the coils will need a day or two to allow things to cool down before you notice a change in the heat around the door.
True 49f fans stopped running.
Compressor still runs. Fixes? Troubleshooting steps?
I am assuming you are relating to the evaporator fan(s) not running. If this is the case, some units have a 'Klixon" type thermostat in the evaporator so when the evaporator coil temp reaches a predetermined temperature, the fans come on. You may have a bad "Fan Delay" (Klixon) or the coil is not reaching the proper temp to activate it to turn on the fans. I would check the wiring diagram on the unit for this part to see if this unit has it in the system.
