20 Most Recent Jl Audio E4300 Car Audio Amplifier Questions & Answers
0answers
Kia494 IC
Be the first to answer 11/16/2017 12:00:08 PM • Jl Audio E4300... • Posted on Nov 16, 2017Be the first to answer
How do I get rid of a squelch when the set is turned on?
what set are you referring to
8/26/2016 6:35:50 PM • Jl Audio E4300... • Answered on Aug 26, 2016
0answers
How do i know if my amp is fried
If it keep on going into the (Protection) Mode, Minimiun $150 end up to have it (Repaired)
11/12/2012 8:32:45 PM • Jl Audio E4300... • Answered on Nov 12, 2012
2answers
My JL audio 1000 x 1 hooked up to 2. 15 Sundowns I play it and then after awhile it shuts down and says low voltage why is this happening
sounds like the amps not rated for the resistance tha subs have it running at....are they a dual 2 or dual 4 ohm?is the amp rated for 1ohm? sounds like amps going into protect mode
7/10/2019 11:59:33 PM • Jl Audio Car... • Answered on Jul 10, 2019
2answers
I have a jl audio jx500-1d went on protection mode and already disconnect every cable to it and try it again but same thing goes to protection mode
Sounds like you either shorted something out or overloaded the amp. Is there any odor coming from it? If so It will need to be repaired or replaced. What did you have connected to it and how was it wired?
5/12/2019 6:00:42 PM • Jl Audio Car... • Answered on May 12, 2019
2answers
JL AUDIO JX 1000.1D protect light comes on some damage to rca's but no visual loose connections ...help
You will need to open it up to see if anything damaged. That does not look good at all from the outside.
5/12/2019 5:52:43 PM • Jl Audio Car... • Answered on May 12, 2019
I have a jl audio jx 1000 .1 and I have two hifonics 12 both are 4 ohms subs how can I wire them to my amp for best results?
In your world, what does best results mean to you. how are the hifonics mounted? open air, closed box, vented box (optimized to what freq)? trunk or inside vehicle? all these variations weigh heavily on your configuration. As does what 'best results" means to you.
11/19/2018 10:02:04 AM • Jl Audio Car... • Answered on Nov 19, 2018
I have a jl audio 250/1v2 when I plug in the power wire it comes on but then Shut off why is that
Check your ground to make sure it is properly grounded
5/2/2017 4:48:18 AM • Jl Audio Car... • Answered on May 02, 2017
Jl audio amplifier keeps going into protection mode
Disconnect all the speakers one at a time and see if it stops doing that, if it does you have a shorted speaker or wiring
11/18/2016 10:55:51 PM • Jl Audio Car... • Answered on Nov 18, 2016
I can't find where the fuse is located at on my jl audio model e6450 so I can check and see if it's blowed are not
Amps that big are usually fused on the feed wire, under the hood of the car, near the battery.
1/30/2016 12:31:21 AM • Jl Audio Car... • Answered on Jan 30, 2016
Jl Audio E4300 Car Audio Amplifier Logo
6 questions posted
Top Jl Audio Car Audio & Video Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jl Audio Car Audio & Video
Most Popular Question
get rid squelch when set turned
  • Car Audio & Video
