20 Most Recent
Jl Audio 250/1 Car Audio Amplifier Questions & Answers
I have a Jl Audio 250/1 mono block amp and the
It could be a number of things? 1 to many subs, speakers wired to the amp causing it to overheat and making the thermal light come on. 2 It all depends were your amp is. If it's clear and nothing covering it, obstructing it, Ie sub in front of it, amp inbetween the rear seats and sub.
My amp only powers on it gives no power to my subwoofers
1st check to see if the RCA's are plugged in if they are make sure the speakers are plugged in. Check at the amp and at the sub Alson check the input voltage switch. JL Audio Slash series amps have a high/low switch for your input voltage. And the last thing I can think of is if your using a remote wire to turn the amp in make sure the signal sensing switch is off. If your not using a remote wire turn it on....Hope this helps
I need to repair my amp it sill produs's sound but
So your saying that you bought the amp and it was loud? And now it's not loud anymore? Check the settings on your amp and turn it down or up (in your case) and make sure your stereo has your bass up or how ever else you would like it
