20 Most Recent Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Questions & Answers
2answers
TDA9381PS/N2/3I1041 alernate ic name...?
To my knowledge there is not an alternate circuit. Take a closer look, the number you gave is for a vertical defliction IC.
11/15/2017 10:47:20 AM • Samsung 24.8 Cu.... • Answered on Nov 15, 2017
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
6/16/2017 7:01:04 AM • Samsung 24.8 Cu.... • Answered on Jun 16, 2017
0answers
MODEL RS2544SL NOT COOLING
Do you see ice on the back wall of the freezer?
2/2/2014 4:53:46 PM • Samsung 24.8 Cu.... • Answered on Feb 02, 2014
We cannot change the temperature of the freezer. Everything,even the water to the ice machine is so frozen (8*) that we cannot get ice. How do we change the temperature
I am not sure what model you have, but on my RF265AABP there are two buttons and digital displays at the top of the refrigerator, visible when the doors are open. One sets freezer temperature, the other refrigerator temperature. On my model if they read 88 88 with a blinking digit, it indicates a broken wire to a temperature sensor, usually the ice maker sensor since it tends to get snagged and damaged easily.
12/24/2013 3:40:51 PM • Samsung 24.8 Cu.... • Answered on Dec 24, 2013
After a sever thunderstorm and a power outage of 7
Hi b_marquis,
To reset the unit just hold down the Power cool and Power freeze button for about 10-20 seconds. This will reset the machine and it should start again.
Hope it helps.
Thank you for using FixYa.
3/1/2012 11:41:01 AM • Samsung 24.8 Cu.... • Answered on Mar 01, 2012
3answers
RS267LBSH/XAA Thunderstorm, very quick off/on
Hi
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Daniel
7/3/2011 7:12:42 PM • Samsung 24.8 Cu.... • Answered on Jul 03, 2011
The refrigerator is not cooling. freezer still
The fan is probably hitting ice, which did not defrost. Most likely culprit is the defrost timer. This will build up and prevent cold air from circulating from the freezer to the refrigerator. You can remove the rear panel in the freezer, expose the ice, melt it with a blow dryer(careful not to electrocute yourself) and replace the panel. If it occurs again within a week, then the defrost timer is either bad, the fuses to the timer need replacing or the thermostat is not telling the timer when to turn on.
6/20/2011 3:25:20 PM • Samsung 24.8 Cu.... • Answered on Jun 20, 2011
I have a Samsung RS2545SH Side by Side.The
which temperature you set the freezer
3/12/2011 2:12:12 AM • Samsung 24.8 Cu.... • Answered on Mar 12, 2011
Refrigerator is freezing everything
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
2/25/2011 4:28:57 AM • Samsung 24.8 Cu.... • Answered on Feb 25, 2011
The water dispenser is not working, I have checked
the ice maker has a different solenoid that works it so id say either the switch on the door or the other water solenoid is at fault
2/6/2011 10:45:59 AM • Samsung 24.8 Cu.... • Answered on Feb 06, 2011
Our fridge is making a beeping sound every 2 to 3
those have a high temp warning,, anytime the freezer or fridge goes above a set temp it will beep,,, make sure all or the doors are shutting good and the gasket is sealing,, if they are try to find any cold air coming out,, if all is good,, you need to get a service tech because it could be a bad fan, or a bad sensor
1/24/2011 4:45:44 AM • Samsung 24.8 Cu.... • Answered on Jan 24, 2011
Freeze side is ok , refrigerator side is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1/13/2011 3:08:13 AM • Samsung 24.8 Cu.... • Answered on Jan 13, 2011
The tempature light is blinking on the freezer
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
1/1/2011 3:34:30 PM • Samsung 24.8 Cu.... • Answered on Jan 01, 2011
Completely lost all power
check to make sure that there is still power to the wall outlet. the outlet might be bad or the circuit breaker may have just tripped.
c...
12/31/2010 7:55:05 AM • Samsung 24.8 Cu.... • Answered on Dec 31, 2010
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
44 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
model rs2544sl not cooling
  • Refrigerators
