20 Most Recent
HP Compaq Presario V6000T Notebook PC Questions & Answers
Back light turns off and on hooked up to the charger at almost full charge what can i do to fix this kind of issue?
This could be a power issue. If the charger port on the computer. If it got to hot or bumped or something either port on the computer could have been damaged. The charger itself could be going bad. Also might even be a virus causing it to change the settings. Worse casethe backlight on the screen is failing.
Checking your display setting could help. Running virus scans could help. Might need to replace backlight and/or screen. Might just need to reinstall windows all together.
9/17/2017 11:18:17 AM •
HP Compaq...
Answered
on Sep 17, 2017
Deleted built in mic
Hello there!
just try these:
1) use a checkpoint recover time a day before the deleted mic.
2) do a refresh in device manager, and install the mic driver.
1/26/2017 4:59:13 PM •
HP Compaq...
Answered
on Jan 26, 2017
4 beeps in compaq v6000 lp
ok try this shut down laptop hold down function key microsoft button the B button and power all at the same time will put you in bios look forset to default settings and save and exit let me know what happens
3/4/2013 7:13:46 PM •
HP Compaq...
Answered
on Mar 04, 2013
Compaq wifi driver
Hello,Thank you for posting your question in fixya.com.You can find the wifi driver for compaq by visiting this
website . Click on Drivers and Updates and look for your computer. Enter the correct operating system and install the driver for wifi. If you want to make sure all your computer's driver is updated, you can install an automatic updater like RadarSync to your computer. It should work. I hope this helps!If you have any questions, please drop me a line. Carlo
1/23/2013 4:41:07 AM •
HP Compaq...
Answered
on Jan 23, 2013
My computer is showing script error line 57,
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.Thus it is advised to please avail paid fixya services for better support and quick solution.Thanks
10/21/2011 4:44:33 AM •
HP Compaq...
Answered
on Oct 21, 2011
Sir mere laptop me sound nahi h kuch help kro
Hi, just choose your operating system and then press next and now you can download your required driver free for life. just open this link or copy past into your browser and follow my instruction.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3177516
Good Luck and please rate my solution
2/4/2011 2:55:08 PM •
HP Compaq...
Answered
on Feb 04, 2011
I am using linux mint 8 and now trying to install
The Grub bootloader that Linux uses may be conflicting with the install program for Windows.
I suggest formatting the partition you had Ubuntu installed on if your intent is to replace it.
This should make the partition available to Windows 7.
If you wanting to dual boot then i'm sorry you can't at the moment because of compatibility issues between wubi/mint4win and grub2, Linux Mint 8 comes without a
Windows installer. The development team is working on the issue and new ISOs will be published when it is resolved.
Keep your eye on the Mint 8 website for the latest ISO with the windows installer included.
Regards.
7/1/2010 5:18:49 PM •
HP Compaq...
Answered
on Jul 01, 2010
I keep getting a "not responding " message. What steps can I do t
I have a solution to your problem. there can be many things wrong with your pc, but the most common problems are that your computer could have malware or a virus , or your computer is getting enough memory to run, because of that it stops responding, what i recommend you doing is getting a good cleaner like advanced system cleaner and cleaning your computer, from all the junk thats taking up your memory,, also try not to run too many programs at once... uninstall programs you dont use,,, if none of those things work i recommend you scanning your pc with a good antivirus program to search for trojans and malware... also clean your registry advanced system cleaner has a pretty good registry cleaner.... good luck.
6/4/2010 9:32:08 PM •
HP Compaq...
Answered
on Jun 04, 2010
Setup Error -
if u want to install winXP1st step format ur pc by vista cd then install WIN XP htere no need to buy just get tour firend ,ok.
2/13/2010 12:46:19 AM •
HP Compaq...
Answered
on Feb 13, 2010
HP COMPAQ V6000 BUILT IN MICROPHONE NOT WORKING
download an antivirus make a full scan of the drives. try again, if it doesnt work, then reinstall windows on it. download also the latest driver for the sound. hope this work. if still not then buy an external mic
8/9/2009 1:12:45 PM •
HP Compaq...
Answered
on Aug 09, 2009
Built in microphone
Try going to the control panel, then system, then device manager, find your audio icon and delete it(highlight it and press the "delete" key on your keyboard) then reboot your computer and see if it works then.
7/31/2009 9:12:49 PM •
HP Compaq...
Answered
on Jul 31, 2009
Dont know
You have a problem with your RAm most probably. There is a chance of a problem with the hard drive also
Try to increase the virtual ram and see(You can do it by getting system properties and by moving to Advanced->Performance.
Set it to system managed size
6/17/2009 9:50:14 PM •
HP Compaq...
Answered
on Jun 17, 2009
Driver installation
Deinstall SP3. Nothing works with it.
If you can't deinstall it, you'll have to reinstall Windows, I'm sorry.
I hope this helps,
Yannick.
6/17/2009 12:00:42 PM •
HP Compaq...
Answered
on Jun 17, 2009
