20 Most Recent
SimpleTech 2TB SimpleDrive Pro Duo External USB 2.0/eSata II by Fabrik Hard Drive Questions & Answers
How do I set Simpletech Duo Pro to be RAID 1 in
The SimpleTech user guide (http://www.simpletech.com/support/guides/user-guides/Duo-Pro-User-Guide-11012007.pdf) does not correctly describe the reset sequence to switch the RAID level.
The correct reset steps, I learned after talking to technical support, are:
Power down
Depress (and hold) reset button
Power up
Wait 10 seconds
Release reset button
My external drive will not open on my new HP computer
Unplug the external. Then Try rebooting cold. When the computer stops +30 sec. Reboot the computer and plug the external when you see the HP splash screen.
- If that does not work, make sure you have the drivers for the ext. for your configuration. Win 8, 8.1?
- You can go to the site where your external was developed at and make sure you have latest drivers and if there is a problem associated with your device.
- On newer machines there is also 3.0 USB connections. While it should not make any major difference, make sure that your ext. is not plugged into a 3.0 USB. The 3.0 USB is blue in color.
Can SimpleTech runs on 220 voltage
Not enough info.....
Ask Simpletech. I Dont use simple tech brand but it usually is similar to other products.
Most Hard Drive Boxes are connected to a Power Pak that goes into the AC wall outlet to drop the power down to low DC voltage.
Most power pak's handle 110 & 220 ac these days. Read the tiny writing on the power pak label. It's usually marked as input & output.
Good Luck
