20 Most Recent
Westinghouse L1975NW Monitor Questions & Answers
Monitor keeps timing out
Without doing a physical test of the system, it is like shooting in the dark. Timing out may relate to capacitance. If a failing capacitor on the circuit board is intermittent, it starts to build up a charge and then quickly discharges.
Again, proper test equipment is required to trace the circuit and find the problem.
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
How can I fix an
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Mac monitor resolution
Click on the apple icon in the upper left corner and select "System Preferences" from the menu to open the preference panel. Then click "displays" on the panel (it should be listed under hardware and will have a monitor icon). There you can see all of the resolution options.
Windows XP SP3 does not
Problem might be with your graphics drivers
Confirm by following process
Right click on my computer and then click on Manage.
then Choose device manager from left panel of the window
then list of hardware will appear.
if there is exclamatory mark over your graphics drivers then right click on it and then click on update device software
if it doesn't work then install it from your drivers disk, you got it with your motherboard.
Basic "background" colors are wrong:
Kathy...have you tried connecting another monitor to the same video card and computer? It could be...
1. Video card defective
2. VGA cable from computer to monitor defective...look for bent pins in plug.
The VGA cable from the computer video output carries three distinct colors...red, green and blue. Likewise one of these colors may not arrive at the monitor correctly or at all. The results being that all colors are incorrect.
It tuns green and when you turn on computer it
Your monitor cable may be bad. This happens. Try a different cable.
If not, try a different monitor to ensure the computer is displaying. Also make sure everything is plugged in firmly (not HARSHly, just tight).
Also, try testing the monitor with a laptop. This will eliminate whether the monitor is shot.
How can I fix an "Out of Range" display?
It means that your display card settings are too high for your monitor. Boot your system into safe mode (press F9 as it boots up) and set the display settings lower. Right mouse button click on an empty space on your desktop and go to properties. Then settings->advanced->Monitor and you should be able to adjust the vertical frequency down to 60hz or 72hz. If you get the out of range message on boot up then you will need to try out a different screen on your system, boot into Windows, change the settings and then plug in your original monitor.
Shuts off when i plug in vga cable
try replacing the vga cable but first check for bent pins .if there grounding out on each other it will cause it to shut down good luck
Screen Flickers and won"t stay on. what is causing
Please read here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
