20 Most Recent
RCA CC285 Camcorder Questions & Answers
How can i power up my cam without the wall adapter or a battery that will not charge so i can see if it even works anymore?
yes you can "Rig" something up,but make sure you are using the right voltage as well as the right milliamps the cam is made to recieve.this is Very important. and of course make sure the wires you are using to power the cam are not touching or crossing each other at any time, and they do not touch the wrong contact in the camera as well. I have found using a piece of cardboard and taping the wires to it, keeps the wires seperated. good luck, and take your time when connecting your wires.
5/20/2014 3:49:08 PM •
RCA CC285...
Answered
on May 20, 2014
Switched on - battery OK - no function light, will
This sounds very much like a tape jam and the camera is trying to un-load the tape but it is stuck round the capstan, run the tape back a little if you can, that should release it from it's snag area okay.
8/27/2013 2:30:38 AM •
RCA CC285...
Answered
on Aug 27, 2013
When the battery is on the charger there is 2
Yes, when both lights are on.. it means the battery is charging. The "charging" light should turn off once the battery is fully charged.
If the "charging" light remains on 12 or more hours later, your battery might need to be replaced.
5/16/2011 8:41:13 AM •
RCA CC285...
Answered
on May 16, 2011
I cant get my tape to play for longer than 3
That monster looks old. My guess is that the battery is not holding enough of a charge and may need replacement. Can you plug this into the wall for power? Are you getting any error codes?
2/3/2011 7:05:10 PM •
RCA CC285...
Answered
on Feb 03, 2011
Have a cc275 that looks just like the cc285 at the
If you have not already tried it, use a wet or dry tape in an attempt to clean the video head, I recommend the dry tape because it is easier on the mechanism. The other option is to use a store bought blank tape and run it on sp mode the fastest speed and let it run through. If you still have trouble, buy a swab kit with cleaning fluid from Radio Shack, open the door so you can clearly see the video head. Now dip the swab in cleaning fluid and put swab against the head "gently" use the other hand "top part" to manually turn the head one or more times around for a deep cleaning and allow several minutes to dry, this a good opportunity to clean the rollers and other parts with Q-Tips and fluid to finish the job. If none of these work it probably indicates a bad video head.
1/19/2011 7:13:11 PM •
RCA CC285...
Answered
on Jan 19, 2011
RCA CC604 VHCS Camcorder. My old camcorder won't record?
Question edited into written English with punctuation.
The lens isn't black, the viewfinder is black. Connect it to a television or computer and see if playback and live recording is working. In that way you know the optics and the electronics are working. The viewfinder is a small LCD display screen with a magnifying glass in front of it. Take it to your local camera shop, they will know someone that still repairs these camcorders.
I was hoping to find a free PDF manual as I wondered if there is a switch or a setting to turn OFF the viewfinder?
https://www.google.com/search?q=RCA+CC604+VHCS+Camcorder+manual
2/11/2023 11:54:21 PM •
RCA Video...
Answered
on Feb 11, 2023
RCA CC433 will not record or play back tapes
You can first check for any debris in the video tape player and double check that no settings are stopping the tape from playing (ie a stuck rewind button) . Otherwise, please use the services of geeksquad/bestbuy to refurbish your vcr player. You might also check out BandH (?) video to see if they can refurbish your video tape player.
Thank you.
11/18/2022 6:23:14 AM •
RCA Video...
Answered
on Nov 18, 2022
