20 Most Recent
Sharp LC-52D64U 52 in. LCD HDTV Questions & Answers
Power light flashing no picture no sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Audio will not turn all the way up
The audio must have been locked at setup to a particular volumes, say, hotel mode etc. If you want to disable it, you have to enter its service mode options. If you wish to get more details, surf this link.
There are more than two thousand and four hundred posts. All are related
to television and other domestic electronic equipment service help. More than
Nine and half Lakh viewers cannot be
wrong.
Tv wont turn on used
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
