20 Most Recent
Sharp LC46SB54U 46 in. LCD TV Questions & Answers
Is it normal for opc
You can turn this feature of in you menu. It is adjusting to change in roomlighting when you see this come on. Look in your menu for OPC on off setting under features menu.
Sharp Aquos E203 No Broadcast now
My LC46D64U just started doung the same thing for any over the air channel that starts with 6. It cuts out for a few seconds about every 60 seconds. Has anyone found a solution for this?
How to remove the base from your flat screen tv
There are 4 holes on the back of the TV just above where the neck of the base is. Lay the TV face down on something soft that will support the weight and remove those 4 screws. pull the stand off the bottom of the TV.
How do I replace the main board
Main board replacement is a skilled work, as it might need firmware update after replacement. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
