Go to settings/my device/ and scroll down to "call". Then "call alerts". Under "Call status tones" you will find all 3 culprits like "call connect tone", "Minute minder", and "Call end tone". De-select them and you're all set.
This worked for the Galaxy 4. Dig around in settings and find it for your model.
Hi Sarah, If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. BUT if you've forgotten your pattern code The link below is a youtube video of a guy shows 3 way but the 3rd way is a factory reset meaning you loose every thing in your phone
but the first two ways are worth watching. Also there's videos down the right side that may help..... I hope this helps...... CHEERS..
EASY WAYS How To Unlock Android Passwords
Check youtube. Be better off to take it to a local phone shop though. Sometimes it's easy, but sometimes the digitizer is glued to the glass. (S4 for example) and then you're in worse than you were before.
You may have a temp fix if it's just the glass cracked by putting a screensaver over it, which will smooth out your contact surface and protect your finger from glass. shards.
It can be cheaper to just by another Android on Craigslist.;) Good luck!
You can't. If it was stolen, it has been reported or Samsung has the registered user for the phone. I found a phone someone tossed out. Nice but was blocked by the owner who told company he bought a newer phone. Even to unblock it, you won't be able to gain service.
On the rear of your TV connect, with a phono/RCA cable to the Audio R + L sockets, connect the other ends to your Yamaha using the TV in sockets. See photos attached
Hope that helps. HDMI is for video unless the extra pins are added for audio.
