20 Most Recent
Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder Questions & Answers
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
2/24/2022 6:36:58 PM •
Panasonic...
Answered
on Feb 24, 2022
Fault u81
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web
5/16/2012 4:46:08 AM •
Panasonic...
Answered
on May 16, 2012
Error code FO6 onVCR
Hello
It is due to busy and confused memory IC by so many unfamilier external commands. Just reset the device to its factory setting.
The ratings level returns to the factory preset. While the disc tray is open, press
[DRIVE SELECT] to select the DVD drive, then press and hold REC button and PLAY button on
the main unit at the same time for 5 or more seconds ("INIT" will appear on the unit's display).
Leave it for some time till initilisatin has beed done.
OK.
7/20/2011 5:58:34 AM •
Panasonic...
Answered
on Jul 20, 2011
Dmr-ex85 shows u81 code and is not functioning at
Physically unplug power from the unit for a minute or two.
Connect power cord to unit and Simultaneously Press & Hold
both the [STOP] and Channel UP [^] for 5 seconds. This will
force Eject the DVD tray. Remove any disc if present.
Cycle the power again if necessary and wait for the unit to
go through its self check cycle. If after several attempts, and
you continue to get this error, then your Ram drive may need
to be replaced.
7/14/2011 1:13:41 AM •
Panasonic...
Answered
on Jul 14, 2011
