20 Most Recent
Gaggia Tebe Espresso Machine Questions & Answers
Steamer not working
check solonoid valve,usually valve is clogged!you need open top,after you will see coil and valve,remove coil and you need open valve and clean!
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Gaggia titanium leaking from the bottom
If the machine only is leaking while the water tank is attached, but is correctly inserted, then the intake line could be broken or disconnected. This will require a repair. If leaking only occurs while the machine's pump is activated then the drain area of the machine might be blocked
