20 Most Recent
Polaroid i1032 Digital Camera Questions & Answers
Computer is new and software is old. where can I find the exe file to support windows 8
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa (
http://picasa.google.com ).
How do I get pictures from camera to computer. The computer is new and has windows 8
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
Is not connecting via usb
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
I have a Polaroid i1032
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Camera not working
Unfortunately, if the batteries have corroded then the chances are extremely high that the contacts (and possibly more of the camera's internal electronics) have also been affected by corrosion. It may be possible to clean the contacts yourself, but if there is corrosion internally then the camera is probably not economically repairable.
Polaroid iD1660 not accepting memory card
you dont say what size or type of card you have there? did you previously use the card elsewhere? format the card on a PC using SDFORMATTER (google it) hope that sorts.
Delete amazon account
A factory reset will restore your Kindle to factory conditions and removes any content you've downloaded to your device, be sure to back up your personal content to your computer first. You will be able to download all your Amazon purchases from Archived Items after registering a new device or application.
To factory reset your Kindle:
1. From the Home screen, press Menu.
2. Select Settings.
3. Press Menu again and select Reset to Factory Defaults.
Your Kindle will then begin to reset. This may take a few minutes to complete.
