20 Most Recent Polaroid i830 Digital Camera Questions & Answers
what does it tell you in the owners manual.
Polaroid i830... | Answered on Jan 06, 2015
FixYa is an online advice site manned by volunteers working in their own homes around the world (I am in the UK). FixYa do not make or sell any brand of anything, and they can not respond to warranty or service claims. You would need to contact the manufacturer or seller of the item for that.
Most of the questions on this site are posted for free, and the answers are free. Many questions do not get answered, often because there is no useful answer to give, or because none of the volunteers knows the answer.
You can also post a paid-for question. These are more likely to get answered, if an answer is possible. If you have posted a paid-for question, and were not helped, I believe that you need not pay. I don't know the mechanism, but some of the paid-for questions I have tried to help with had payment refused or refunded, so if you are not satisfied, take it up with the site admin.
Polaroid i830... | Answered on Dec 26, 2014
its in system settings
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Polaroid i830... | Answered on Jul 29, 2014
http://www.polaroid.com/support
Polaroid i830... | Answered on Apr 18, 2014
Try to download the required software from Polaroid. Every computer needs software (and a driver) so it can transfer the pictures from a camera to the computer. The software always comes with the camera. but if you don't know where the CD is, try the firm of your brand.
If that won't work (some brands no longer exists and some on't support that long) you always could try some free software like from Ulead, Pixir, BeFunkey, Gimp, Photoshop express. Or if your camera does have a memory card, buy a external card reader and use that to transfer the pictures and videos to your computer.
Polaroid i830... | Answered on Feb 15, 2014
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Polaroid i830... | Answered on Apr 16, 2013
I bought one today , and I had the same problem. I tried four brand new pairs of batteries and when I pressed the power button it just wouldn't work. I was going to return it tomorrow, but decided to try it again. I inserted the batteries that it originally came with and it finally worked. I tried the other batteries and it worked also, but not on the first try, in the third or fourth try. Maybe on the first few tries the batteries need to warm up? Anyway, it's working now.
Polaroid i830... | Answered on Nov 26, 2012
Hi and welcome to FixYa,
Your described problem maybe attributed to corrosion on the camera's battery contacts. Perhaps you could try to clean the contacts. At times it may even be necessary to scrape them a bit to expose fresh metal. In some other instances, it may also help to slightly bend/stretch theses contacts so that they exert more pressure on the batteries,
Good luck and thank you for using FixYa.
Polaroid i830... | Answered on Jul 31, 2012
Look on the card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.If the slide has broken off then the simplest fix is to get another card.
Polaroid i830... | Answered on Apr 21, 2012
Hit Menu, scroll right to Date Stamp and set it to OFF.
Also, could try in the user guide: polaroid.com/support_detail?p=4031
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Polaroid i830... | Answered on Feb 14, 2012
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Polaroid i830... | Answered on Sep 04, 2011
Take your memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Polaroid i830... | Answered on Aug 30, 2011
Polaroid i830 Digital Camera Logo
114 questions posted
Top Polaroid Cameras Experts
Ekse
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
I Polaroid
  • I Polaroid
Most Popular Question
i830 digital camera reads card locked
  • Cameras
