20 Most Recent
Hisense LHD3206US Television Questions & Answers
Need remote control code for hisense EN-21660A
Does anyone know where I can get a remote for a Hisense 22" TV? I've bought a universal remote but after reading other people's experiences with the Hisense remote, I'm reluctant to even try it.
3/14/2014 3:21:20 PM •
Hisense...
Answered
on Mar 14, 2014
Our hisense tv says
you can make use of the remote control to remove the lock
5/20/2010 8:39:33 AM •
Hisense...
Answered
on May 20, 2010
Lcd screen is blank
The cold cathode (backlight) is the reason. If not busted then its ballast must be burnt out already
5/17/2010 1:09:56 PM •
Hisense...
Answered
on May 17, 2010
Digital Television sound synchronisation
The pixel problem your having is signal strength related, the sound is always affected first. If your on cable, have them come out and check the signal strength first.
5/17/2009 12:28:16 AM •
Hisense...
Answered
on May 17, 2009
I have a mag 254 iptv and a Hisense TV. The remote codes clash and the two are unusable in tandem. Can the remote control codes on the Hisense be changed?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; to which you want set-up codes; in the "
Search box at the top right of the display window" to get gathered related posts.
3/27/2024 7:09:19 PM •
Hisense...
Answered
on Mar 27, 2024
How can I re-program Hisense TV remote control / model EN - 31201A
Often the instructions for programming a TV remote control is included in the TV manual. The EN 31201A remote came with several TVs including the Hisense F39V77C. The manual for this TV only lists a few cable and satellite box codes:
https://www.manualslib.com/manual/594196/Hisense-F39v77c.html?page=11#manual . This page refers you to the manufacturer's site for additional codes. The Hisense-usa.com site did not list the specific TV that I found that used the EN31201A remote.
Since the F39V77C first shipped in 2012, the remote would probably be limited to use with devices that were built in 2011 or earlier. I recommend a universal remote that includes support for streaming devices. Unfortunately, I don't know which support Fubo TV specifically. Most packaging advertises Roku or Amazon Fire support. You can find the code lists for some RCA universal remotes online. (Most of the others require finding a code written inside the battery compartment to determine the remote generation and code list.)
I wish that I had better news for you.
12/13/2023 10:57:09 PM •
Hisense...
Answered
on Dec 13, 2023
