20 Most Recent
Compaq Evo N600c Notebook Questions & Answers
Good day Sir/Madam
my windows is
no OS stated, it has an operating system what it it.
Windows ? Linux, OS2 what?
IT IS 16 YEARS OLD, 2001 PC. WHY Mess or speed cash on something that has zero value?
it came with windows 2000
are you trying to put say W7 (the oldest currently supported MS OP)? here>
the oldest PC here has only a 16GB hard drive.
W7 will never fit that in a millions years.
XP fits, but is a VIRUS magnet, why be in the news headlines
IZia gets, Cyber-attacked? do not be a virus magnet, upgrade.
ok?
to install say XP
first erase the whole, HDD.
if the F10 key is dead, (HPs restore partition recovery is dead.)
you then buy HP media kit for this PC from HP.
then using it erase the whole HDD.
now XP fits.
in a used computer store here, for $20 we have 10year old pC for sale. USA< not 16 years. ones this old are crushed and recycled.
My windows xp professional crashed.
Make sure you have the BIOS set to first try to boot the CD tray, you can do that by accesing the BIOS set up which is at the beggining and you should press F12 or some F key (depending on the laptop)
If by doing that youre not able to restore, I should recommend using a Linux live CD and backuping all the important files you have.
You can also buy or upgrade to a newer windows and use the "keep my documents" option where you normally keep your documents and upgrade every other part of windows.
in my laptop (compaq evo
enter the bios and set the first boot to dvd/cdrom also check the compatibility in the ide configuration try to set to enhanced or to compatible
Screen color is messed up screen is like purple
Try to bring it to a shop. The plexcable of your notebook is not properly attach causing it to turn purple. Use the warranty of your notebook and bring it to the shop to check or to repair.
I have a 2002 Compaq
You may have to contact Verizon for this so they can connect you. They will ask for such things as your computers' MAC address which can be found on a sticker on the bottom of the computer chassis. The MAC address is a unique identifier for your computer. Much like a fingerprint no two are the same. The signal strength that your computer is showing you is rather misleading; it is meant for notifying you of the connection between it and the wireless signal being sent from another device such as a satellite or wireless router, NOT that you are actually receiving data from the internet. There are some other parameters and internet protocols that your computer will need to be set up for, all of which your internet service provider (Verizon) will get established for you over the phone. It shouldn't take more than 10 minutes.
When i turn on computer
This could be a Windows password or a system password or both. If you
don't have the Windows password and the former owner can't tell you what
it is, you might have to erase the disk, reinstall Windows and thus
solve the problem. A System password is a theft protection that can only
be changed if you know the password. It is embedded in the laptop
hardware. Ask the former owner what the password is, otherwise there is
no solution but to ask Compaq Service.
Dear Experts,
I am not able
Hello Sir;
You can write any Data to the CD by two ways.
* By Sending the Data to the CDROM Drive
* By using some CD Burning Software
1. Just Select and Right Click the Data that you need.
2. You get a small menu and choose Send to Option and select your
CDROM Drive.
3. After the file is sent get into the CDROM Drive in My Computer and
select the option
Write these files to CD from the left side pane on
first option.
Your done.
* By Using Burning Software
http://hotfile.com/dl/47576902/c5bbc36/RPK.NE.NCD.NIT.10_LatestPirate.CoM.rar.html
Laptop crashed put windows back in cant find
Frequently, Compaq laptop computers have their wireless buttons on the forward facing corner of the case. Usually on the right side, you can see it if you open the lid/monitor, then look at that corner. If you see what looks like a wireless icon, press it, and then a lighted icon should light up next to the corner on the right.
If these two things do happen, your WiFi is turned on.
I have ust got this compacq evo n600c and cannot
Try going into device manager
click start
then control panel
then system
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
Hope this helps
N600c's bios can't support 48-bit lba?
It depends what you want to use the laptop for but Windows XP SP2 (Disk needs Service Pack integrated), Windows Fundamentals for Legacy PC's and Windows Vista and Windows 7 will correctly address a hard drive within a machine that has the 137gb 48bit LBA problem.
I have a sony evo n600c and when it starts up its
This error is commonly seen in Compaq laptops.
Take out the battery,start the laptop with the adapter only and see if that error message pops up again and if not then it might be your battery.Usually battery life is 3yrs.
Put the battery back again and see if the message pops up again.
Try the battery on a different laptop.
It could be the Voltage Converter Board...see service manual for the same or call Compaq service centre.
Installing a new HD will I have to re-install windows?????
No, a new hard drive means you'll have to re-install Windows from the CD's that originally came with the notebook (or a retail copy of Windows as well) and all of the programs and files that you had before. A new hard drive is totally blank.
