20 Most Recent
Dell Inspiron 640m Notebook Questions & Answers
Hello, I recently changed
Look on he power adapter and some of the old dells has to have a 65 amp and you might have the 90 amp check to see which one you have. the 90 amp is for the docking station
My microphone is not working
Hi Ramin
Please check to make sure:
1). The MIC is not Muted
2). The Internal MIC is the default Sound Output device.
3). Update the drivers (even if they are the latest, re-install them)
Andrew
Battery not charging
Try running the battery completely flat and then seeing if it will charge but it is most likely that you will need a new battery.
How to recover deleted ISP program on laptop wireless computer?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled, If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Cant change screen size
If the computer will not let you adjust the screen resolution go to dell's website and search your computer model. Download and install the latest video/graphics driver for your computer. That should fix the issue.
Keyboard failure
This may be an issue with your usb drivers. Update those first, then if that fails, I would try one of those adapters that goes from USB to the old school mouse and keyboard connections and plug that in to see if it works.
INSPIRON 640M WILL NOT GO INTO SAFE MODE , IT
Try going to safe mode manually. The steps mentioned below will help you accessing the safe mode
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Safe Mode/Safe mode with networking".
Step 5: Select that and HIT ENTER.
My dell 640M doesn't run on AC mains power but
A bad or weak adapter.It will charge the battery when off but won't run the laptop by itself.Also it could be a bad power jack where it plugs in.I would try a good adapter first to see.
