20 Most Recent Koolatron (785169015699) Questions & Answers
3answers
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
2/19/2021 2:17:26 PM • Koolatron... • Answered on Feb 19, 2021
2answers
KOOLATRON VENDING MACHINE, FAN WILL NOT WORK
customer service helpline at 1-800-265-8456
2/18/2021 10:05:44 PM • Koolatron... • Answered on Feb 18, 2021
0answers
0609032993
Be the first to answer 6/16/2014 3:23:50 AM • Koolatron... • Posted on Jun 16, 2014Be the first to answer
2answers
WONT RUN
compressor is not starting . you might try a 3 in 1 booster pack.
5/21/2014 4:31:37 PM • Koolatron... • Answered on May 21, 2014
0answers
0answers
Skybox compressor is out can not find replacement-maytag no help!
From what I remember, no parts are avable for repairs. They don't want you to fix, they want you to replace.
9/16/2012 11:34:59 PM • Koolatron... • Answered on Sep 16, 2012
EC-23 machine, fans seem to
If the fan is running then the problem is most likely the Peltier junction cooler.It will have to be replaced.
1/23/2012 1:37:07 AM • Koolatron... • Answered on Jan 23, 2012
0answers
2answers
When I plug in my koolatron EC-23 the power LED
The noises are a sign that the power source is overstressed by a short and it goes in and out of protected mode. Before replacing it you must find out if the short is on one of the other components or the psu itself: disconnect it from your device and start it alone - if it still makes the noise or the voltages on its outputs aren't ok then it's definitely dead.
Yes, it can be replaces with one, but you will have to modify the connectors and the wiring.
2/22/2011 8:18:19 AM • Koolatron... • Answered on Feb 22, 2011
0answers
0answers
0answers
Stopped working
Be the first to answer 7/10/2010 2:39:59 PM • Koolatron... • Posted on Jul 10, 2010Be the first to answer
My koolatron mini vending fridge
hello. these are neat little fridges arent they. your situation is normal and you can let it leak as it is or you can follow the maintenance routine outlined herein:
Periodically you will need to remove, clean and dry the tray where the cans fall onto when dispensed. This will require more frequent attention in humid conditions. High humidity will also cause condensation inside the unit that should be wiped up with a dry cloth. When cleaning, turn off the power switch and disconnect the power cord. Vacuum out the ventilation grills on the back of the unit. Use only a damp warm cloth and a mild detergent for cleaning. Avoid the use of harsh cleaning agents and solvents. If storing the Vending Machine please switch off the power, disconnect the power cord, then clean and dry it thoroughly.
10/11/2009 2:15:50 AM • Koolatron... • Answered on Oct 11, 2009
Koolatron (785169015699) Logo
Popular Tags
30 questions posted
Top Koolatron Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
ADMIN Eric
ADMIN Eric
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Koolatron Refrigerators
Most Popular Question
koolatron vending machine fan will not
  • Refrigerators
