20 Most Recent
Koolatron P-85 Questions & Answers
My Koolatron cooler runs but
Peltier went bad and they usually do. Easy to replace but you will need thermal paste compound. The one they use in installing a processor in a motherboard of a computer. If you decided to not fix it at least save the cord because those price at $27 and they can go bad to after a while.it's worth learning how to fix it because you save money in the long run by not buying a new one.
My cooler was working great and now it is not
Bear in mind that these coolers can also warm, depending on the orientation of the power cord connection. One end of the power cord has an arrow, the other end has a blue dot on one side and a red dot on the other. For cooling, connect power cord ends so that the arrow is on the same side as the blue dot. If the arrow is on the same site as the red dot, the cooler becomes a warming device, venting cold air outside the cooler and into the car. Could that be the problem?
Hi! My Koolatron fan
Hi ronwarn,
If your fan is not "catching" up, thus it need a nudge or two, it signs of fan wear.
You should actually replace it.
Regards :-)
* If you found this solution helpful, please accept it.
