20 Most Recent Koolatron CocaCola Fridge Red Compact Refrigerator Questions & Answers
0answers
Not working
Be the first to answer 7/12/2017 3:42:03 AM • Koolatron... • Posted on Jul 12, 2017Be the first to answer
The Power Supply box burned out where can I get a new one?
that is the only way to get the replacement : the manufacturer
5/26/2013 12:55:25 PM • Koolatron... • Answered on May 26, 2013
0answers
Pf error code
Be the first to answer 5/5/2013 10:40:25 AM • Koolatron... • Posted on May 05, 2013Be the first to answer
Frig clicks on then off on then off continuous
Do you mean the compressor kicks on and off like it is trying to start? Please explain your problem a little more for me.
1/1/2012 5:44:37 AM • Koolatron... • Answered on Jan 01, 2012
COCA COLA ANNIVERSARY PROMOTION AWARD 2010
i have reacived a msg 4rm coca cola promotions &itjames at [email protected].&gt:my mobile no has won$1,000,000.00 pound in the cocacola anniversari lucky draw,2011 and they cuming 23th oct,dp.mike john wil be cuming tomorrow so i need to go airport to pick him or wat paper work should i do andi think they charged me money 29,900INR SO should i trust him this promotion wat should i do he is cuming tomorrow
10/23/2011 12:35:12 PM • Koolatron... • Answered on Oct 23, 2011
0answers
I have received a message
my self vikash deep. my mobile no. won 750000 pounds
1/5/2011 9:46:42 AM • Koolatron... • Answered on Jan 05, 2011
0answers
Koolatron mini fridge quit working
That clicking is probably a relay. It needs professional diagnosis. If it is small you can just take it to a refrigeration engineer and save the call out charge.
10/11/2023 7:05:13 PM • Koolatron... • Answered on Oct 11, 2023
Can I fix my koolarton cooler?
If your Koolatron cooler is not cooling down, even though the fan is working, there may be a problem with the compressor or the refrigerant. The compressor is a critical component of the cooling system, as it is responsible for compressing and circulating the refrigerant that absorbs heat from the air inside the cooler. If the compressor is faulty or damaged, it may not be able to compress the refrigerant properly, resulting in poor cooling performance. The refrigerant is a chemical substance that absorbs heat from the air inside the cooler and carries it to the compressor, where it is compressed and released. If the refrigerant level is low, the cooler may not be able to absorb enough heat to cool the air effectively. To fix this problem, you will need to diagnose and repair the faulty component. This may require the assistance of a qualified repair technician, as repairing a cooler's cooling system can be complex and hazardous.
12/10/2022 10:38:47 AM • Koolatron... • Answered on Dec 10, 2022
Koolatron 6 bottle wine cellar is beeping and temperature is flashing
The only way to make it stop is to unplug it. And to make it stop permanently is to take it to a recycling center and wave bye bye to it. :(
11/5/2022 3:36:11 PM • Koolatron... • Answered on Nov 05, 2022
My Koolatron mini Coca-Cola fridge has a flashing green light instead of the normal solid one and the fan isn't running. How do I fix this?
Hi, this sounds like hardware damage. You might want to setup an appointment with your local geeksquad to have the fix the issue for you. Or you can call koolatron and request the fix. Doing internal harward repair on your own could be a dangerous task, so that's why I mad my suggestion. Thank you.
9/30/2022 1:43:14 AM • Koolatron... • Answered on Sep 30, 2022
I have a koolatron cvf18 inside fan quit working where i find a replacement
Direct from Koolatron
RETRO VENDING FRIDGE thermoelectric cooler ... - Koolatron
https://www.koolatron.com > CVF18G-manual
PDF replacement parts, please telephone the following numbers ... CVF18-G. Please Read These Instructions Carefully Before Use! S.V.P., lire ... For long periods of storage, a small container of baking soda or charcoal, placed inside, will eliminate.
4/10/2021 10:09:32 PM • Koolatron... • Answered on Apr 10, 2021
Koolatron P34 schematic needed
Request the wiring diagram (not a schematic) directly from Koolatron.
12/8/2020 3:54:18 PM • Koolatron... • Answered on Dec 08, 2020
My koolatron does not get cold replaced the motor run but still does not get cold
Did you regas unit after motor replacement?
9/17/2019 10:25:45 AM • Koolatron... • Answered on Sep 17, 2019
Koolatron CocaCola Fridge Red Compact Refrigerator Logo
Popular Tags
21 questions posted
Top Koolatron Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
ADMIN Eric
ADMIN Eric
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Koolatron Refrigerators
Most Popular Question
power supply box burned out get new one
  • Refrigerators
